tình hình hum nay em nhân đươc 3 máy 1200.1650.6030 tình trang giống nhau,lên chớp tắt,em flas lai = mxbox,= hwk,tình trang vẫn như nhau.flas 2 file mcu,ppm,thi chay ok ko báo lỗi nhưng ko boot wa log đươc,còn chay 3flie thì báo thế này,đã thay cáp đa năng,ốp lưng.not ok. log nó day ae. MXKEY Serial: [MxKey HTI FLASHER INTERFACE 1] - C0855BFC
Using device: HTI BOX, FW ver: 00.07
Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0089 8874 [Intel 28F640W18,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
UEM ID: 00942CAFA3BDA66
ASIC type: 11
UEM Imei: 35574402790716
Flash Imei: 35574402790796
Invalid imei checksum !
Processing MCU file: rm305_06.000
[DCT4,DCT4 ALGORITHM] size: 2.33 MB
Supported Ids: 2292
UEM ID: 00942CAF:2984DA60
Area [01000000-0100FFFF] erased in 0.625 s
Area [01010000-0179FFFF] erased in 1 min 13.078 s
Area [017A0000-017EFFFF] erased in 3.578 s
Area [01F00000-01FDFFFF] erased in 0.343 s
Flash programming ...
Programming completed in 23.891 s
File Processed in 1 min 48.047 s
Processing CNT file: rm3050_nai6.00mq
[DCT4,DCT4 ALGORITHM] size: 194.27 KB
Supported Ids: 2292
Area [01760000-0179FFFF] erased in 2.656 s
Programming completed in 2.187 s
Aborting operation ...
Content extract fail, continue anyway ...
File Processed in 50.593 s
Processing PPM file: rm305_06.00mq
[DCT4,DCT4 ALGORITHM] size: 2.91 MB
Supported Ids: 2292
flashing terminated !
Task failed at (0800002A)!!!
Last RX buffer: 02 00
Operation aborted by user request!
flas 3 e đều giống nhau,
A3BDA66
: 0934.80.22.28 . Gmail :
