Kết quả 1 tới 10 của 18
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    Mặc định 5130 CONTACSEVIC cần anh em giúp
    ae cho em hoi không co mxbox co repair SD được không vậy ,
    May 2010
    ĐIỆN BIÊN
    cs ra sao bạn.cho cái log bus check lên coi sao đí
    TRUNG HIẾU MOBILE
    MXKEY Serial: [FT SCR2000 0] - C0853609
    Driver: UFS2XX, ver: 3.8.14.0, NTMP ver: 2.8.14.0
    Module ver: 1.0.0.16978(13-05-2011), Library ver: 1.0.0.10071(13-05-2011)
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 09D0000AEE9B7D5603D93E74A0C982A6387D5B98
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
    TransmissionMode: DDR&TX2
    Original Imei: 35322303398967
    Original Product code: 0571958
    Bluetooth ID: 002547FDACE2
    Phone Type: RM-495 (Nokia 5130c-2)
    SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
    Imei plain: 35322303398967-5
    Product Code: 0579020
    Battery voltage: 4699 mV, current: 79 mA
    Language Pack:
    - not available.
    This is SL3 phone(Simlock2 format).
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST failed!
    Imei net: 353223033989675
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    nó đang bị lỗi này
    nhưng không có mx box nó không cho repair SD ae ai có cách giải quyết nào khác không giúp em với
    đợi em chút xíu nha
    nhà mình đâu hết oy ?
    Buôn Ma Thuột City.
    Using device: J.A.F, FW ver: 01.B1
    RAP Data :
    EM1 ID: 00000296
    EM2 ID: 00000B22
    PUBLIC ID: 1D400117AABC7E5693174CFF4997EB47F515DC90
    ASIC MODE ID: 00
    SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP
    ExtDEVC: FFFF 0000 - 0000 0000
    Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
    RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
    Original Imei: 35422303885142
    Original Product code: 0571943
    Bluetooth ID: 0025CF194E2A
    SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
    Imei plain: 35422303885142-4
    Product Code: 0571943
    Language Pack:
    - not available.
    This phone have PM308 protected, SD security in not restorable.
    - Avoid manual erase to this phone !
    SIMLOCK_TEST passed
    Imei: 354223038851424
    Provider: Nokia Test, Country: Finland
    Counter: 0/3, 0/10
    BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
    Scanning local SX4 Card ...
    No SX4 Card found.
    Authenticating using security server ...
    Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 124.6.181.28
    SUPERDONGLE auth succeeded!
    Writing PM from Node ...
    Section: 1
    - Key: 0, size 12 bytes written.
    - Key: 1, size 70 bytes written.
    - Key: 2, size 70 bytes written.
    - Key: 3, size 70 bytes written.
    - Key: 4, size 70 bytes written.
    - Key: 5, size 276 bytes written.
    - Key: 6, size 276 bytes written.
    - Key: 7, size 276 bytes written.
    - Key: 8, size 276 bytes written.
    - Key: 9, size 384 bytes written.
    - Key: 10, size 384 bytes written.
    - Key: 11, size 384 bytes written.
    - Key: 12, size 384 bytes written.
    - Key: 13, size 384 bytes written.
    - Key: 14, size 384 bytes written.
    - Key: 15, size 384 bytes written.
    - Key: 16, size 384 bytes written.
    - Key: 17, size 32 bytes written.
    - Key: 19, size 16 bytes written.
    - Key: 20, size 32 bytes written.
    - 120 skipped
    - 308 skipped
    Section: 309
    - Key: 0, size 4 bytes written.
    - Key: 1, size 2 bytes written.
    - Key: 2, size 12 bytes written.
    - Key: 4, size 12 bytes written.
    - Key: 5, size 12 bytes written.
    - Key: 7, size 12 bytes written.
    - Key: 8, size 12 bytes written.
    - Key: 17, size 12 bytes written.
    - Key: 22, size 12 bytes written.
    Completed in 5.047 s
    RAP Data :
    EM1 ID: 00000296
    EM2 ID: 00000B22
    ASIC MODE ID: 00
    Language Pack:
    - not available.
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Counter: 0/3, 0/10
    : 0934.80.22.28 .
    May 2010
    ĐIỆN BIÊN
    pmm auth cho nó cái sau đó write pm 1 và 309 vào >>>done
    TRUNG HIẾU MOBILE
  9. ( QUANGTRUNG_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    nhathuy_mobile2009 (18-10-2011)
  10. #9
    Buôn Ma Thuột City.
    Cái này mình cũng sưu tầm thôi ,đã gặp và thành công nhờ cái này ,Bạn thử xem
    : 0934.80.22.28 .
  11. ( GIA NGUYỄN_MOBILE ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #10
    V.I.P ThanhHai_GSM's Avatar
    mxkey tam dừng chân nếu bạn có ATF cho vao repair ok
  13. ( ThanhHai_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 7210c contacsevic cần anh em giúp
    By nhathuy_mobile2009 in forum BB5
    Bài viết cuối: 08-03-2012, 07:58
  2. 5130c contacsevic cần ACE giúp đỡ
    By KHACVINOKIA in forum BB5
    Bài viết cuối: 02-03-2012, 10:05
  3. 1200 báo contacsevic giúp đỡ
    By phattai2011 in forum DCT4 - WD2
    Bài viết cuối: 11-09-2011, 16:51
  4. 3110c contacsevic xin giúp
    By tranthao in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 15
    Bài viết cuối: 14-12-2010, 10:55
  5. Nokia 5130 contacsevic ....
    By AnNam_Mobile in forum BB5
    Bài viết cuối: 04-12-2010, 12:14
