Kết quả 1 tới 10 của 13
    Feb 2011
    thanh hóa
    Mặc định 6230i xin anh em giúp
    tình hình em mới học chạy phần mền .nên ko biết 6230i là dct4 hay bb5 .em cho dct4h thì nhận .chek info ok .
    Getting MCU ID
    MCU ID: 0x1052
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 003500EC <=> SAMSUNG (SEC) -> K5E5657ACB Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 03.88
    28-Jul-06
    RM-72
    GSM P1.1
    (c) NMP.
    HW version: 3002
    PCI version:
    UEM version: 400
    UPP version: 4178
    RFIC version: p
    10ff11ff0205
    DSP version: p
    B0446T_05w14
    LCD version: SHARP
    PPM version:
    ADSP SW version: TIKU_PB_04w47_06_w01
    Production serial number: PEI622659
    Product code: 0522071
    Module code: 0202552
    Basic production code: 0519797
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356644005545780
    IMEI spare to net: 3A 65 46 04 50 45 75 08
    IMEI SV to net: 33 65 46 04 50 45 75 28 F4
    Master Code: 1351243322
    Phone type: RM-72, Software version: 03.88, Language Pack: not available
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-72.ini
    Setting local mode...
    Reading product code...
    Product Code: 0522071
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
    Checking path: \Products\RM-72\
    No ini files found...
    Done!
    nhưng khi chạy not ok
    khi em bỏ cổng bb5 j .nhưng lại chạy bên dct4 .thì ko chek nhưng info được
    .các anh hướng dẩn dùm em .em xóa đi nạp lại thì .mcu,cnt,ppm < not ok > nhưng khi werpm thì ok ,unlok ok . ime vẩn còn .nhưng ko có sóng ,rất mong các bác chỉ dùm
    Feb 2011
    thanh hóa
    các mod ngủ hết rồi à .ko ai giúp em với .khách nói mai phải trả máy .thằng khách này chuối quá
    Feb 2011
    thanh hóa
    alo ko ai giúp em với ,nhiệt tình chỉ giùm em với
    Moderator Thuyết Vũ's Avatar
    Gia lai
    dct4 bạn ah. 6230i là dct4 mang qua hwk hay mxkey mà chạy nhé. thân!
    p/s lấy 3.88 mà chạy là oke. con này ngày xưa gọi là new chip đấy
    Iphone Shop Thu Vân-sửa chữa apple Chuyên Nghiệp
    507 Nguyễn Huệ Núi Sập Thoại Sơn An Giang.YM: phong_vugl mobile: 0974444438
    Tài Khoản Vietcombank Gia Lai chủ tài khoản : Vũ Tiến Thuyết 0291002263263
    V.I.P ThanhHai_GSM's Avatar
    chú ý dòng máy 6230i file flash khác nhau E và M
    Feb 2011
    thanh hóa
    Trích Được post bởi ThanhHai_GSM Xem bài viết
    nhờ thanh hải giải thích thêm .cho em tí .hôm qua em chạy doen nhưng lại ko có sóng .wer pm.unlok ok rồi
    bình phước
    máy bình thường có sóng ko bạn, trc khi bạn flash đó, ko thì xóa full nạp lại cho em nó cai xem sao.
    Feb 2011
    thanh hóa
    Trích Được post bởi phone_lucky Xem bài viết
    xóa nạp rồi .pro mà vẫn not ok .ại qua yahoo sen giùm em với
    khucnhacsau_khucnhacsau
    file ppm và cnt của 6230i có dạng như thế này khác nhau chữ E và M
    ppm: rm72_73_110E_03.62v
    cnt: rm72_73_110E_03.62.ucp_v
    nếu bạn chạy file có chữ E không đc chạy lại file chữ M
    Feb 2011
    thanh hóa
    để em nạp lại coi có gì em báo cáo
  1. 6230i bệnh lạ cần ae giúp
    By Công Chức_GSM in forum DCT4 - WD2
    Bài viết cuối: 06-08-2012, 10:44
  2. 6230i xin giúp
    By khanhhung99 in forum BB5
    Bài viết cuối: 02-11-2009, 14:49
  3. giúp em con 6230i với các bác ơi ....
    By anhvandoicho0812 in forum Game Nokia
    Bài viết cuối: 04-12-2008, 18:42
