e nhận cây x2-00 chết nguồn e thay ic nguồn chạy xong nó báo thế này nhờ các bác xem dùm em cái log
MXKEY Serial: [FT SCR2000 0] - C0843E1B
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.67
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: rm618__08.25.mcusw
[BB5,XSR 1.6] size: 26.97 MB
Supported Ids: 2200050920030000, 22000509200C0000
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: F8A95B4
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000002C71A42356C4A9E64C91D6EFEE8354
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35342304725428_CE RT.rpl).
CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 32.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-011BFFFF]
CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF]
CMT FLASH,MuxOneNAND area [02500000-028FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT ADA block sent
CMT RAP3NAND block sent
CMT ISA+DYNSW block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT UPDAPP block sent
Programming completed in 6.312 s
Processing PPM file: rm618__08.25.ppm_v
[BB5,XSR 1.6] size: 6.98 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01D00000-024FFFFF]
Programming completed in 1.641 s
Processing CNT file: rm618__08.25.image_v_0595227_008
[BB5,XSR 1.6] size: 21.06 MB
Erase size: 76.31 MB
CMT FLASH,MuxOneNAND area [02900000-0753FFFF]
Programming completed in 5.125 s
Total time for flashing process(boot+erase+write) was 17.578 s
Warning: Phone did not reboot to normal mode.
Market items is empty, please select the correct products path !
