1202 rớt nước mất nguồn, máy còn động , mở nguồn kim dòng nhít nhẹ rồi về o, đã khò lại nguồn , u , và flash , check ra ok, nhưng fash thì bị lổi thế này mong mấy ace giúp, thanksssssss.
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
Using device: HTI BOX, FW ver: 00.17
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Boot error: CC CC CC 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
flashing terminated !
Task failed at (08000027)!!!
Last RX buffer:
			 : 0934.80.22.28 . Gmail :
