ATF Software Version v7.79
ATF Box FBUS Flash Started...
Number of Image Files: 3
MCU Version: V 07.21 05-11-08 RM-237 (c) Nokia.
IMEI Plain : 353225032854701
IMEI Spare : A353225032854700
IMEI SV    : 33532250328547025F
Phone Model: Nokia 3110c
Product Serial Number: MKO068086
Product Code         : 0514949
Module Code          : 0203291
Basic Production Code: 0542523
MCU SW Version       : V 07.21 05-11-08 RM-237 (c) Nokia.            V
BT MCM Version       : 06cc-P9.1
PPM Version          : V 07.21 05-11-08 RM-237 (c) Nokia.
HW Version           : 5008
RFIC Version         : 17211721
DSP Version          : ICPR61_08w10
AHNE Version         : 11
Retu Version         : 32
Tahvo Version        : 53
   ********   Reading SimLock   ********
CONFIG KEY:  0000000000000000
PROVIDER KEY:  2440700000000000
Provider  :  AT&T;U.S.A. (3650)
Counters  :  0/3  ,  0/10
   Block [1]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [2]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [3]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [4]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [5]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [6]  1:Open 2:Open 3:Open 4:Open 5:Open
   Block [7]  1:Open 2:Open 3:Open 4:Open 5:Open
SP Lock Status :  Not Locked
SIMLOCK_TYPE             : PA_SL1
SIMLOCK_TEST             : PASSED
SECURITY_TEST           : PASSED
SECURITY_CODE          : 12345
PHONE_MODE              : TEST MODE
PM 308 Found...
 SimLock Certificate Saved to :  C:\AdvanceBox Turbo Flasher\Nokia\Backup\353225032854701\SL1_certifica  te_V 07.21 05-11-08 RM-237 (c) Nokia._353225032854701_Not Locked_15607.pm
Changing MODE : FLASH
AdvanceBox SendBootCodeEx
InitialiseBootstrap_DCT5 DIR
BootFlashMode_DCT5
                  TIME STARTS HERE
SYSTEM_ID_RESPONSE_BB5 (0xC0) - 0  (0x00) bytes returned
Number of Sub Blocks 7  (0x07)
  1  SYSTEM_ASIC_ID 01
     Block Length  : 21  (15)
     BB ASIC Index : 0  (00)  CMT
     ID DWORD    0 : 00000001
     ID DWORD    1 : 00000226
     ID DWORD    2 : 00010006
     ID DWORD    3 : 010C1921
     ID DWORD    4 : 01001101
  2  ROM_ID 15
     Block Length  : 5  (05)
     ID DWORD    0 : 00000232
  3  ROM_ID 15
     ID DWORD    0 : 00000353
  4  PUBLIC_ID 12
     ID DWORD    0 : 20200214
     ID DWORD    1 : 0DA07E56
     ID DWORD    2 : 003C1F5E
     ID DWORD    3 : A36B56D9
     ID DWORD    4 : 5B674A87
  5  ASIC_MODE_ID 13
     Block Length  : 2  (02)
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
     Block Length  : 17  (11)
     Hash          :  BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
  7  ROM_ID 15
     Block Length  : 9  (09)
     CRC         0 : 191EC665
     CRC         1 : DFAAF68F
Checksum           AF
SearchForBootstrap_DCT5..
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
Boot File - Version  010.042.00
Boot File - Revision 0x0000 (0)
eBB5ProtocolType == Original
SearchForBootstrap_DCT5  : No Error - 0 (0x00)
Secondary Loader Sent...
 MessageID  : 03
 SubBlocks  : 03
 1 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   BB ASIC Index     : CMT  00
   Device Type       : NOR  00
   Device Index      : 00
   Manufacturer Code : 0089 ->
   Device ID         : 8981 -> NU48F256
   Extended/Fixed ID : 0000
   Revision ID       : 6A21
 2 Sub Block ID      : 11  STORAGE_DEVICE_CONTENTS_BB5
   Block Length      : 13
   Device Index      : 00
   Device Contents   : 00000000000000000000
 3 Sub Block ID      : 10  STORAGE_DEVICE_ID_BB5
   Block Length      : 0B
   Device Type       : MMC  04
   Device Index      : 00
   Device ID         : 0000 -> BAD FLASH TYPE
   Revision ID       : 0000
 Checksum   : 82
FLS1SendAlgoCodeEx..
SendAlgoCode_DCT5..
SearchForAlgorithm_DCT5..
Looking for ALL Devices...
Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21
Flash Descriptor
   Device ID         : 8981
   Revision ID       : 0000
   Size              : 02000000 (32 MB)
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 64
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
VPPInfo : VPP_INFO_3V_MASK  VPP_INFO_9V_MASK
C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
Algorithm File - Version  010.040.00
Algorithm File - Revision 0x0000 (0)
SearchForAlgorithm_DCT5  : No Error - 0 (0x00)
TransmissionTypeRequest_DCT5...
SuggestedType  : 01 16BIT
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 01 DC
ReturnedType : 01 16BIT
TransmissionTypeRequest_DCT5  : No Error - 0 (0x00)
Uploading ALGO File...
Pabub KEY Request
PHONE_INFO_RESPONSE_BB5
   PAPUB_KEYS_HASH_RESP_BB5 2A
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
C0E691EA16A7593A9BB28832D7312A39F7ED668D
START READING RPL DATA
Reading : NPC (CMT)
OK
Reading : VARIANT (CMT)
OK
Reading : CCC (CMT)
OK
Reading : HWC (CMT)
OK
Reading : R&D (CMT)
OK
Reading : PARTNERC (CMT)
 PARTNERC :  Empty
Reading : MDM_KEYS (CMT)
 MDM_KEYS :  Empty
FINISHED READING RPL DATA
 RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\backup\353225032854701\3532250328547  01_15623.rpl
FlashInfo.RestartMode : 2
Processing Image File :
 C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.30.mcusw
CMT Type : BB5
CMT Algorithm : BB5 ALGORITHM
Secondary Sending Speed    : 3250000Hz
Algorithm Sending Speed    : 6500000Hz
Program Sending Speed      : 6500000Hz
Message Reading Speed      : 98000Hz
Number of Blocks :  945
Entry Point:  0x453C
Page Format : -1
MAX PAGE : 0x00004000
VBATT OFF...
VBATT ON
Setting VBATT Done!...
BootFlashMode_DCT5
                  TIME STARTS HERE
BootFlashModeDCT5Ex Succeeded after 3 Attempts
  1  SYSTEM_ASIC_ID 01
  2  ROM_ID 15
  3  ROM_ID 15
  4  PUBLIC_ID 12
  5  ASIC_MODE_ID 13
     Mode Id       : 00
  6  ROOT_KEY_HASH 14
  7  ROM_ID 15
     CRC         0 : 191EC665
     CRC         1 : DFAAF68F
Checksum           AF
 MessageID  : 03
 SubBlocks  : 03
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 6A21
   Block Length      : 13
   Device Index      : 00
   Block Length      : 0B
   Device Index      : 00
   Revision ID       : 0000
 Checksum   : 82
SendAlgoCode_DCT5..
Flash Descriptor
   Device ID         : 8981
   Revision ID       : 0000
   VPP Info          : 0009
   Erase10s          : 28
   Block1s           : 64
   BErase1s          : 02
   Reserved0         : 00
   Reserved1         : 00
   Reserved2         : 00
Pabub KEY Request
   BB Asic Index   : 00
CMT PAPUBKEYS HASH:
Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT  00 only)
Certificate 1
  ASIC Index  : CMT  0
Certificate 2
  ASIC Index  : CMT  0
Certificate 3
  ASIC Index  : CMT  0
STORE_CERTIFICATE_REQUEST_BB5 : 61 03 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 A2
STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
VPP Enabled by Software
Using Internal VPP
StartErase_DCT5...
BlockLength  :  0x4E  (78)
ERASE Blocks :  0x01  (1)
     0   ERASE_AREA_BB5 0x12
            Block Length     : 0x4B (75)
            BB ASIC Index    : 0x00 CMT
            Device Type      : 0x00 NOR
            Device Index     : 0x00
               0             : 00000000-000006BF
               1             : 000006C0-0001FFFF
               2             : 00020000-0007FFFF
               3             : 00080000-000DFFFF
               4             : 00100000-001FFFFF
               5             : 00200000-0031FFFF
               6             : 00320000-0105FFFF
               7             : 01060000-01067FFF
               8             : 01068000-0107FFFF
Erase_SendEraseBlock_BB5_NOR
Task in Progress... Please Wait...
Status_BB5 STATUS_REQUEST_BB5..
1  Sub Block ID      : 14 STATUS_NOR_OK_BB5
           Block Length      : 01
           BB ASIC Index     : 00
Successfully erased..
Time Taken to Erase : 00:01:20
TRANSMISSION_TYPE_REQUEST_BB5 :  59 01 20 01 04 D9
ReturnedType : 04 DDR & 2TX
Flashing Speed: 5.00 Mhz
Processing  : rm237__07.30.mcusw
Total blocks to write : 945
         FBUS Cable RX2 PIN Diagnostics
1  Sub Block ID      : 16 PROGRAMMING_ERROR_BB5
           Block Length      :  0F
           BB ASIC Index     :  00
           Error Type        :  05
           Error Spec        :  08
           Offending Address :  00000400
           Expected Content  :  0000933D
           Detected Content  :  00009300
Reconnect your Cable Properly because RX2 PIN
is NOT getting any DATA from the Box!!!
ERROR: RX2 PIN is NOT CONNECTED PROPERLY !!!
 Flashing FAILED
BB5_WRITE_FlashFile_0
Go to Settings -->
Nokia Settings -->
FBUS DDR&2TX Synchronization Timeout
Change the current value selected to a higher value
and Restart AdvanceBox.exe software to apply it
 Operations Failed....
