em đã đóng lại nguồn , u , flash, bây giờ chạy phần mềm báo lỗi thế này máy vẫn còn dao động, nhờ mấy pro giúp, thankssssssssssssss
đây nè anh
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
Using device: HTI BOX, FW ver: 00.17
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Performing Flash Authentication ...ASIC type: 11
UEM Imei: Empty
Flash Imei: 35606703793912
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\_BACK.rpl"
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
Performing Flash Authentication ...Area [01000000-0100FFFF] erased in 0.906 s
Area [01010000-013AFFFF] erased in 53.469 s
Area [013B0000-013EFFFF] erased in 3.610 s
Area [017C0000-017EFFFF] erased in 0.078 s
Area [01FC0000-01FEFFFF] erased in 0.062 s
Flash programming ...
Programming completed in 14.141 s
File Processed in 1 min 23.735 s
Processing CNT file: rh1120_nai04.03mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
Performing Flash Authentication ...Area [01380000-013AFFFF] erased in 2.766 s
Programming completed in 0.735 s
Content extract fail, continue anyway ...
File Processed in 8 min 55.406 s
Processing PPM file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Boot error: CC CC CC 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
flashing terminated !
Task failed at (0800002A)!!!
Last RX buffer: 02 00
máy bị rớt nước.
sao ko đo xem mạch của mh có đứt ko nhỉ???
lỗi như vậy phần đa là gio cáp kiẻm tra cáp chạy ok mà ko lên thì xem lại màn hình
sỹ Hải_mobile
kiểm tra thật kỹ màn socket màn hình xem có đủ 2 áp không có đủ thì thay thử màn khác chưa gì đã vội làm ic sớm thế bạn
anh oi, không có điện áp cho mh.
làm ơn cho em xin mạch đèn 1202
