máy lúc đầu bị đánh rơi rồi kẹt phím xưống. tắt nguồn khởi động lại thì lên chớp tắt rồi mất nguồn. em flat thì báo lỗi như sau. ae xem qua xin cho ý kiến giúp đỡ.
thanks all
đây là log của em nó;
MXKEY Serial: [FT SCR2000 0] - C0845DFF
Connection status: UHCI:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 0610010A39960254EA08FE2639D8856B64D12497
ASIC MODE ID: 00
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
eBB5ProtocolType: OLD
Storage0: 00EC 220C - 0000 8921 [Samsung K8F1215ETM,512 Mbits] type: FLASH,NOR, asic:CMT
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
TransmissionMode: 16Bit
TransmissionMode: DDR&TX2
Processing MCU file: rm242__09.40.mcusw
[BB5,BB5 ALGORITHM] size: 20.36 MB
Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000
Erase size: 21.87 MB
CMT FLASH,NOR area [00000000-0001FFFF]
CMT FLASH,NOR area [00040000-000BFFFF]
CMT FLASH,NOR area [000C0000-0013FFFF]
CMT FLASH,NOR area [01480000-015FFFFF]
CMT FLASH,NOR area [00140000-0147FFFF]
Error while erasing, Result: 00000000000000 , 50
Total time for flashing process(boot+erase+write) was 5 min 37.437 s
