    Thành viên tích cực mobjado's Avatar
    Mặc định mọi người xem giùm em cái lock c2-01
    máy giờ lên nguồn treo đơ
    MXKEY Serial: [FT SCR2000 0] - C084B8F0
    Driver: nmwcdc, ver: 7.1.32.67
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Reading Important data ...
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35791104945612_PM .rpl).
    Processing MCU file: rm721__11.10.mcusw
    [BB5,XSR 1.6] size: 28.57 MB
    Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100
    NOR pagesize not defined, no changes will be made to CNT.
    Battery voltage: 4633 mV
    Phone type: RM-721 (Nokia C2-01)
    Product code: 059D635
    SW version: V 11.10 - 13-05-11 - RM-721 - (c) Nokia
    LanguagePkg version: 0 - 13-05-11 - RM-721 - (c) Nokia - V
    Version from phone: 11.10
    Version from file: 11.10
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 193352DF
    CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x]
    CMT EM0 ID: 00001051
    CMT EM1 ID: 00001060
    CMT PUBLIC ID: 2320000E5DF45E405765139279250F97611AFDEE
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D
    CMT ROM ID: 67E82268F29CEA60
    Loading CMT secondary boot code
    SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0
    Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35791104945612_CE RT.rpl).
    CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 37.69 MB
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-0009FFFF]
    CMT FLASH,MuxOneNAND area [000A0000-0025FFFF]
    CMT FLASH,MuxOneNAND area [003E0000-005DFFFF]
    CMT FLASH,MuxOneNAND area [005E0000-010DFFFF]
    CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF]
    CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF]
    CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF]
    CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 8443ECD5 [] sent
    CMT RAP3NAND block sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 59.390 s
    Processing PPM file: rm721__11.10.ppm_v
    [BB5,XSR 1.6] size: 7.35 MB
    Erase size: 8.87 MB
    CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF]
    Programming completed in 15.328 s
    Processing CNT file: rm721__11.10.image_v_059D635_006
    [BB5,XSR 1.6] size: 18.65 MB
    Erase size: 75.06 MB
    CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF]
    Converting UCP blocks to 128 K.
    Error converting UCP!
    Task failed at (08000009)!!!
    Last RX buffer: 80 10 6F 00
    giúp em vs máy lúc đầu bị mã bảo vệ đem flash lại chạy đến vậy là dừng
    em đã thử lại nhiều lần cũng vậy
    CHDT- QUANGKHAIappstore 0963.290.007
    V.I.P duclam882003's Avatar
    Jan 2007
    HoaLư_Ninh Bình
    Flash lại không hết thì kiếm box khác mà chiến đi bạn .ATF chiến ngọt đó .
    TRUNG TÂM SỬA CHỮA & DẠY NGHỀ CHUYÊN NGHIỆP DUCHIEP MOBILE
    ĐT:0303.624.999*091.583.9989.Số TK:3308205007879-AGB NINH BINH
    TP Hồ Chí Minh
    MX-key flash cùi bắp lắm. chuyển qua box khác thử đi.
    Jan 2009
    Kiếm file khác + chuyển box xem thế nào đã bạn
    Thành viên mới tuanbaichay's Avatar
    Mar 2010
    Đúng rồi đấy bạn ơi. Bạn nên chuyển box khác chơi đi, mình cũng từng chạy mấy con E71,72,e52 cũng bi như vậy đấy. về sau toàn phải chơi bằng phonix thôi
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    mã bảo vệ thì factory thôi,chạy lại xong vẫn ......nhập mã....ko giải quyết được mà đau đầu thêm.kiếm file khác chuẩn chạy đi bạn
  1. ae ai rảnh check giùm cây 3G lock hay W với
    By thuanwhisky90 in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 01-06-2013, 14:45
  2. 3gs nhờ xem giùm w hay lock
    By hieupy in forum iPHONE 3Gs
    Bài viết cuối: 28-04-2013, 12:01
  3. nhờ ae xem giùm cái lock 1200
    By n0t.0nline in forum Phần mềm và các mã lệnh cho Nokia
    Trả lời: 13
    Bài viết cuối: 19-02-2012, 21:39
  4. Trả lời: 6
    Bài viết cuối: 24-04-2011, 19:04
  5. anh em xem giùm mình cái lock n73 này
    By thanglong in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 06-01-2010, 10:31
