có khi lên nokia treo có khi lên được 1 lúc rồi tắt . chạy lại ko hết xóa flash nạp lại luôn rồi vẫn vậy ai đã làm qua rồi xin chỉ dúp em với thank các ae nhiều
sỹ Hải_mobile
				bạn úp cái log lên đây anh em tham khảo xem sao ?
đây là log của nó
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C08477FC
Using device: HTI, FW ver: 00.24, SN: 0000B1FA
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
ASIC ID: 0x2201 [UPP_2M ver: 2]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8
UEM ID: 008AD0CF:2984DA60
ASIC type: 2
UEM Imei: 35276101616627
Flash Imei: 35276101616627
MasterCode: 5366155700
RPL saved to "C:\mobileEx\3.5\data\backup\35276101616627_BACK.r pl"
Phone type: RH-64
SW version: V 5.04 08-06-06 RH-64 (c) NMP
Imei plain: 35276101616627-5
Cellular system: GSM
ASIC ID: 0x2201, type: 2
Ppm Id: MD
Language Pack:
English,Filipino,Vietnamase
Imei net: 35276101616627
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000000002
sỹ Hải_mobile
đã chạy ver 7.02 rồi cũng như vậy rồi xóa nap lại ver 5.04 vấn vậy ae ai đã làm qua xin chỉ dúp
sỹ Hải_mobile
Rpl backup already exist (C:\mobileEx\3.5\data\backup\35276101616627_BACK.r pl).
Processing MCU file: rh64_07.020
[DCT4,DCT4 ALGORITHM] size: 1.84 MB
Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
Area [01000000-0100FFFF] erased in 0.391 s
Area [01010000-013BFFFF] erased in 23.390 s
Area [013C0000-013EFFFF] erased in 1.344 s
Area [017C0000-017EFFFF] erased in 0.297 s
Area [01FC0000-01FEFFFF] erased in 0.297 s
Flash programming ...
Programming completed in 15.578 s
File Processed in 48.172 s
Processing CNT file: rh640_nai7.02md
[DCT4,DCT4 ALGORITHM] size: 169.13 KB
Area [01380000-013BFFFF] erased in 1.797 s
Programming completed in 1.687 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.546 s
File Processed in 27.516 s
Processing PPM file: rh64_07.02md
[DCT4,DCT4 ALGORITHM] size: 1.68 MB
Area [011D0000-011DFFFF] erased in 0.375 s
Area [011E0000-0137FFFF] erased in 10.265 s
Programming completed in 14.485 s
File Processed in 31.219 s
Total time for flashing process(boot+erase+write) was 1 min 46.922 s
Phone type: RH-64
SW version: V 7.02 10-12-07 RH-64 (c) NMP
Ppm Id: MD
Language Pack:
Counter: 0/3, 0/10
sỹ Hải_mobile
dong này đa phần là dính vào CPU thôi bạn ơi
học học nữa học mãi
				thay thạch anh coi bạn niếu ko hết thay ic nguồn ok .đả tét 2 kây
call :0976 001 628
				nếu dùng trong khoảng thời gian nhất định thì chết nguồn=UEM=ok
nếu sử dụng treo rồi tắt nguồn=UPP=ok
tham khảo nhé
nó lúc thì treo lúc thì lên được chút xíu rồi treo tắt
sỹ Hải_mobile
