Kết quả 1 tới 3 của 3
    Thành viên tích cực sydungdtdd's Avatar
    Apr 2010
    Mặc định anh em cho em xin 1 lốc 1110i
    em có cây 1110i bị lỗi mên em thử thay qua mên 2626 chạy thì nó báo ime ???????????? anh em ai có cho em xin lốc vời em chưa mua được mxbook chỉ có mxkey và nbok
    MXKEY Serial: [FT SCR2000 0] - C083B80E
    Driver: uhci:hub:hub:UFS2XX, ver: 3.6.0.0 , NTMP ver: 2.6.0.0
    Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011)
    ASIC ID: 0x2201 [UPP_2M ver: 2]
    SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
    Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
    UEM ID: 00123752:2984DA60
    ASIC type: 2
    UEM Imei: 35867101029298
    Flash Imei: Empty
    Invalid imei checksum !
    Processing MCU file: rh93_07.020
    [DCT4,DCT4 ALGORITHM] size: 1.89 MB
    Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
    Area [01000000-0100FFFF] erased in 0.562 s
    Area [01010000-013BFFFF] erased in 34.047 s
    Area [013C0000-013EFFFF] erased in 1.953 s
    Area [017C0000-017EFFFF] erased in 0.125 s
    Area [01FC0000-01FEFFFF] erased in 0.125 s
    Flash programming ...
    Programming completed in 19.875 s
    File Processed in 1 min 5.625 s
    Processing CNT file: rh930_nai7.02md
    [DCT4,DCT4 ALGORITHM] size: 163.08 KB
    Area [01380000-013BFFFF] erased in 2.375 s
    Programming completed in 1.750 s
    Extracting Content Pack, File Server fake reply for CUI phone.
    Content Pack extracted successfully in 0.156 s
    File Processed in 30.563 s
    Processing PPM file: rh93_07.02md
    [DCT4,DCT4 ALGORITHM] size: 1.50 MB
    Area [011E0000-011EFFFF] erased in 0.563 s
    Area [011F0000-0137FFFF] erased in 14.390 s
    Programming completed in 15.719 s
    File Processed in 40.875 s
    Total time for flashing process(boot+erase+write) was 2 min 17.063 s
    Phone Type: RH-93
    SW Version: V 7.02 10-12-07 RH-93 (c) NMP
    Imei plain: ??????????????-?
    Cellular System: GSM
    ASIC ID: 0x2201, type: 2
    Ppm Id: MD
    Language Pack:
    English,Filipino,Vietnamase
    Imei plain is invalid !!!
    SIMLOCK_DATA corrupted!
    ĐÔ-LƯƠNG-NGHỆ AN
    YAHOO.SYDUNGDTDD_88
    Moderator TÚ CÒI's Avatar
    hà nội
  3. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    sydungdtdd (08-11-2011)
    hà nội
  5. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. 1110i kiểm tra 0 tự động mất 3 sô 0
    By 0978216826 in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 01-05-2010, 12:52
  2. màn hình 1110i màu
    By 0984367600 in forum DCT4 - WD2
    Trả lời: 32
    Bài viết cuối: 09-01-2010, 20:08
  3. 1110i cuu em
    By minhtuanmobilevn in forum DCT4 - WD2
    Trả lời: 13
    Bài viết cuối: 08-12-2009, 10:58
  4. mic 1110i
    Bài viết cuối: 07-12-2009, 20:16
  5. 1110i
    By tronghienmobile in forum DCT4 - WD2
    Bài viết cuối: 27-05-2009, 16:38
