    V.I.P ĐƠ_NGUYỄN's Avatar
    Mặc định xin xem giup log n2760
    2760 bị lổi không đăng ký thẻ sim. em unlock nó thì xài được 1 ngày rồi bị lại. nên em flash lại, thì thấy tốc độ flash rất chậm, và bị lổi thế này, nhờ mấy pro xem hộ, thans all
    MXKEY Serial: [FT SCR2000 0] - C08600EA
    Using device: POTATO BOX, FW ver: 01.B1
    Connection status: UHCI:HUB:USB 1.10 (Full-speed)
    Driver: FTDIBUS, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\35766201969897_BACK.r pl).
    Processing MCU file: rm258__07.60.mcusw
    [DCT4,DCT4 ALGORITHM] size: 10.75 MB
    Supported Ids: 3160, 3161, 3162, 3164, 3166
    ASIC ID: 0x3162 [UPP_8M ver: 6.2]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 00EC 2208 [Samsung K8F5615ETM,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
    ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 001AD629:3B8ADA60
    Area [01000000-0101FFFF] erased in 0.390 s
    Area [01020000-01C3FFFF] erased in 40.125 s
    Flash programming ...
    Programming completed in 6 min 59.329 s
    File Processed in 7 min 56.297 s
    Processing CNT file: rm258__07.60.image_v
    [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.88 MB
    UEM ID: 001AD629:C5A4DA78
    Area [02000000-02DBFFFF] erased in 44.234 s
    Area [02DC0000-02F9FFFF] erased in 6.078 s
    Converting UCP blocks to 128 K.
    Programming completed in 2 min 38.469 s
    Content extract fail, continue anyway ...
    File Processed in 4 min 32.343 s
    Processing PPM file: rm258__07.60.ppm_v
    [DCT4,DCT4 ALGORITHM] size: 3.43 MB
    Boot error: CC CC CC 00
    - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
    - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
    - On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
    flashing terminated !
    ko nhận đăng ký thẻ sim bạn thay ic ko đc câu lại chứ lỗi này ko phải do pm trc hết thay cuuj pin khác đi.h bạn pai chạy cho nó lên nguồn đi nhé
  3. ( duchanh0885 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ĐƠ_NGUYỄN (10-11-2011)
    lúc đầu nó chỉ nhận sim viettell nên em chỉ unlock thôi thì ok. xài được 1 thì bị lại, em chạy file thấp hơn thì lổi thế này,
    đây là log của em nó
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Area [02000000-02DBFFFF] erased in 44.407 s
    Area [02DC0000-02F9FFFF] erased in 6.203 s
    Programming completed in 2 min 38.390 s
    Extract fail, service not ready?
    File Processed in 5 min 0.985 s
    Processing PPM file: rm258__05.62.ppm_v
    UEM ID: 001AD629:2984DA60
    Area [01C40000-01FFFFFF] erased in 12.640 s
    Programming completed in 2 min 1.047 s
    File Processed in 2 min 29.453 s
    Total time for flashing process(boot+erase+write) was 15 min 23.922 s
    Phone type: RM-258 (Nokia 2760)
    SW version: V 05.62 02-07-08 RM-258 (c) Nokia
    Imei plain: 35766201969897-2
    Imei OTP: 35766201969897
    Product code: 0550272
    Cellular system: GSM
    ASIC ID: 0x3162, type: 11
    Ppm Id: V
    Language Pack:
    - not available.
    Imei net: 35766201969897
    Version: SIMLOCK SERVER
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 000000000001000B
    May 2010
    ĐIỆN BIÊN
    lỗi ban đầu thì chỉ do phần cưang thôi bạn.nhưng bay giờ đã làm rồi thì bạn lấy hwk chạy lại cho nó ngon lành lại .và sau đó vệ sinh thật sạch tx sim hàn lại chân tx sim>>>câu ic sim hoặc thay>>>not ok thì uem.nhưng hầu như ko phải mó tới uem
    TRUNG HIẾU MOBILE
    thanks anh . để em thử
    em thay ic sim thấy ok rồi, nhưng kg biết có ok luôn kg hay bị lại nữa . thanks các anh
  1. N2760 hao nguồn động cần a e giúp với.
    By thaomy13072008 in forum DCT4 - WD2
    Bài viết cuối: 05-12-2009, 22:25
  2. N2760 nên tim hiểu
    By VŨ PRO in forum DCT4 - WD2
    Bài viết cuối: 27-10-2009, 16:44
  3. N2760 loa trong nhỏ
    By hungtrung in forum BB5
    Bài viết cuối: 27-06-2009, 21:24
  4. xin file TV N2760 Vr4.22 chỉ cần PPM 4.22
    By tranvantinh in forum BB5
    Bài viết cuối: 09-09-2008, 00:33
  5. TV Cho N2760??? Help
    By trihay in forum DCT4 - WD2
    Bài viết cuối: 17-09-2007, 18:47
