máy bị đổi mã bảo vệ, em đã flash 3 lần bằng usb và full reset factory, reset về 12345 ok, nhưng khi khởi động máy lại hỏi mã bảo vệ nhập 12345 thì báo sai, nhờ mấ anh giúp. thanksss
				 x2_01 hỏi mã bảo vệ xin giúp
				và đây là log của nó
MXKEY Serial: [MxKey Team HTI Flasher Interface (WinUSB) 4] - C0855D93
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.67
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: rm709__08.70.mcusw
[BB5,XSR 1.6] size: 26.61 MB
Supported Ids: 2200050920030000, 22000509200C0000
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E12659F
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000008810217D03318EA70F5D22B25A1C3D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35484204181574_CE RT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 33.88 MB
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
Flash programming ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 6.656 s
Processing PPM file: rm709__08.70.ppm_v
[BB5,XSR 1.6] size: 6.80 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 1.734 s
Processing CNT file: rm709__08.70.image_v_059H2R7
[BB5,XSR 1.6] size: 28.79 MB
Erase size: 75.31 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 7.390 s
Total time for flashing process(boot+erase+write) was 28.234 s
Device connected: nmwcdc\X2-01 USB Phonet, PORT_ID: 1CC6EAB3
Verifying communication to device OK.
Phone type: RM-709 (X2-01)
SW version: V 08.70 29-07-11 RM-709 (c) Nokia
Imei plain: 35484204181574-4
Product code: 059C3M1
Battery voltage: 3988 mV, current: 1 mA
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354842041815744
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
Market items is empty, please select the correct products path !
Reset User Code (to default:12345) ... OK
Completed in 1.484 s
				mang qua phoenix chạy dead phone là ok anh
				mang qua mxkey chạy 1 phát ok rồi , cám ơn anh rất nhiều
Erase size: 8 MB
Programming completed in 1.718 s
Programming completed in 7.391 s
Total time for flashing process(boot+erase+write) was 26.625 s
Battery voltage: 3871 mV, current: 1 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Completed in 1.875 s
				FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
cả cái này thì ok rồi nè
