các bác xem giúp em.sau khi chạy xong ok thì máy bật nguồn nên mỗi chữ nokia dồi trắng tinh luôn.máy thì vẫn nghe gọi ngon àh.MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08600A9
Using device: HTI, FW ver: 00.24, SN: 0001085B
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\35826403636623_BACK.r pl).
Processing MCU file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00C765B9:2984DA60
Area [01240000-0124FFFF] erased in 1.125 s
Area [01250000-0137FFFF] erased in 21.781 s
Flash programming ...
Programming completed in 9.062 s
File Processed in 37.828 s
Processing CNT file: rh1120_nai04.03el
[DCT4,DCT4 ALGORITHM] size: 127.19 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.531 s
Programming completed in 1.078 s
Extracting Content Pack, File Server fake reply for CUI phone.
Content Pack extracted successfully in 0.531 s
File Processed in 22.516 s
Processing PPM file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
Area [01000000-0100FFFF] erased in 1.141 s
Area [01010000-013AFFFF] erased in 1 min 6.672 s
Area [013B0000-013EFFFF] erased in 4.656 s
Area [017C0000-017EFFFF] erased in 0.172 s
Area [01FC0000-01FEFFFF] erased in 0.141 s
Programming completed in 18.125 s
File Processed in 1 min 36.063 s
Total time for flashing process(boot+erase+write) was 2 min 36.407 s
After Flash Processing ...
Reseting Factory Values OK.
Phone type: RH-112
SW version: V 04.03 29-06-09 RH-112 (c) Nokia
Imei plain: 35826403636623-5
Product code: 0562324
Cellular system: GSM
ASIC ID: 0x2293, type: 11
Ppm Id: í(»4
Language Pack:
- not available.
Imei net: 35826403636623
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000030002
