MXKEY [FT SCR2000 0], SN: C0859AE9
Using device: HTI, FW ver: 00.24, SN: 000094DD
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_003.600
Downloading item CODE:hw_b2_rm647_r03.600.fls, num block: 3, size: 3.97 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 1 min 2.344 s
Erasing area 0x00C60000-0x00E4883E ...OK
Programming completed in 55.031 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.187 s
Error reading checksum!
Processing file: rm647_003.60mr
Downloading item CUST:hw_b2_rm647_003.60mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x003286FE ...OK
Programming completed in 31.687 s
Checksum mismatch: Phone calculated 0x0033, software calculated 0x5870
Processing file: rm6470_nai03.60mr
Downloading item CUST:hw_b2_rm6470_nai03.60mr.fls, num block: 1, size: 308.70 KB
Erasing area 0x00EB0000-0x00EFC5BE ...OK
Programming completed in 9.000 s
Checksum mismatch: Phone calculated 0x00F0, software calculated 0x86E6
Total time for flashing process(boot+erase+write) was 3 min 57.890 s
__
