Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 28
    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Arrow Tool Chạy Sony Ericsson Không Cần Box
    Seking no need box, CID49/50/51/52 Flash FREE, Can Unlcok & Change IMEI
    2007-10-29 Seking 3.0.4.7 released, if you are a seking customer, you must install this release.
    2007-10-24 SeKing3.0.4.6 released
    1.Added alert feature while completed operation.
    2.Only discount 1 log under 3 times for unlocking or changing imei to same phone
    For Example: discount 2 logs at 1st times, then don't discount at 2nd and 3rd times, discount 2 logs at 4th, then don't discount at 5th and 6th times...
    notice: only apply to "35" as IMEI header, need discount logs all times for non "35" as IMEI header.
    2007-10-20 SeKing3.0.4.5 released
    2007-10-15 Seking 3.0.4.4 released2.Change application style.
    3.Support UnlockFiles. no need main file for unlock. but needs to download website in Unlock_Files.rar, after the decompression puts the complete document to the Unlock_Files table of contents under.
    2007-09-22 Seking 3.0.3.8 released
    What's new
    1. FIXED: Bugs while unlocking
    2. NEW: Added Limited support for Z310(CID51/52) flash, customize,Reset talk time to 00:00:00,Reset user lock to 0000, Reset flip count to 0.
    2007-09-04 Seking 3.0.3.6 released
    What's new
    1.Add K750 flash、customize(only test)
    Adds the Unlock defeat to repair the function and DB2012 CID50 Read user code Flash & Customize and unlock
    Notes
    Unlock and IMEI Repair is NOT currently supported for DB2020 CID52 or PNX5230 based phones
    Flashing supported for DB2010/2020 CID49/50/51/52
    Unlock is supported for CID49/50/51
    supported IMEI Repair for DB2010/2020 CID49/50/51
    Flash Empty phones
    Warning!!!:if CID49/51 phone is locked, do not Upgrade to CID52
    Notice: Some models are not supported for UNLOCK via DCU 60 cable, but can be unlocked by Cruiser or Serial Cable, if after using identify with the dcu60 cable there is an error starting commands, try with a cruiser or serial cable and it will probably succeed.
    Now you can use Seking:
    Flash (FREE)
    Repair EROM (FREE)
    Customize (FREE, but You MUST have an account, view order details)
    Reset Time needs 1 Credits (FREE, but You MUST have an account, view order details)
    Unlock (needs 2 Credits)
    Repair IMEI (needs 2 Credits)
    Unlock and Repair IMEI (needs only 2 Credits)
    Upgrade CID (needs 1 Credits)
    Change Type (needs 1 Credits)
    Reset security code (needs 1 Credits)
    Reset Flip needs 1 Credits (needs 1 Credits)
    Flash Empty Phones(needs 3-5 Credits)
    Repair Up EROM (FREE) Video Tutorials http://bandung-flasher.com/gsmhelp/i...8f861134963979
    1,Idenrify
    2,Choose Model
    3,Select 'Flash'
    4,click 'Repair EROM'
    Flash (FREE)
    1,Idenrify
    2,Choose Model
    3,add SW and FS files (The firmware edition musts be compatible with the phone)
    4,Select 'Flash'
    5,click 'START'
    Flash + Customize + Reset Talk Time (FREE)
    1,Idenrify
    2,Choose Model
    4,Select 'Flash' + 'Customize' + 'Reset Talk Time'
    4,click 'START'
    Method A Video Tutorials
    1,Idenrify
    2,Choose Model
    3,Select 'Unlock' + 'Unlock Patch'
    4,click 'START'
    Now Support: K310,K320,K510,K530,K550,K610,K618,K790,K800,K818, S500,T650,V630,W200,W300,W580,W610,W660,W710,W810, W830,W850,W880,W888,Z310,Z530,Z550,Z610,Z710
    và đây là bản mới nhất http://www.shenliang.org/cn/download....7_English.rar
    tool này rất hay bạn có thể tải file chạy trực tiếp trên giao diện của tool chạy .Phiên bản cập nhật liên tục , chỉ cần có sợi cáp DCU60 theo máy là chạy ok ,nhưng nói thật là chạy cũng hơi nguy hiểm , chạy thì không chết máy bao giờ nhưng đã gặp tình trạng chạy xong bị khóa mạng . nên mình post lên cho anh em thích nghiên cứu thì lấy về chạy cho vui nha .Gặp khó khăn trong lúc chạy thì gọi mình nha
  2. ( nhatkha ) đã được 15 thành viên cám ơn vì bài viết hữu ích!
    ahuy1001 (18-08-2009), anhphuong8x (07-11-2007), dtddbaochinh (30-07-2009), dtthuyngadp (07-11-2007), GSMTQK (12-11-2007), hao_vp (07-08-2009), Hudu ars 1984 (21-11-2007), huyvuphatmobile (13-04-2008), khuong0484 (16-05-2009), ngoc_hung_anh (28-07-2008), thanhhung49 (26-08-2009), tinhthelong (30-04-2009), trisanghd73 (14-07-2009), tuan_lam61 (09-11-2007), wonbinxin (07-11-2007)
    Thành viên chính thức thanhvinhdtdd's Avatar
    Mar 2008
    chi cho em cách chạ đi anh ơi
    Thành viên mới tinhthelong's Avatar
    Apr 2007
    Mặc định Mình đã reset user lock con K310i ok
    Thanks bro.Nhờ có tool này Mình đã reset user lock con K310i ok.
    Tháo sim ra khỏi máy vẫn để pin ====>Mở giao diện tool lên chọn model máy ====> check vào reset uselock(1credit) ====> Indentify ======> giữ Phím C trên phone ====> cắm cable vào ====> sau đó ô bên phải sẽ hiện lên những hàng chữ trong đó có dòng User Lock:"mã khoá máy".
    Mở máy lên và điền mã đó vào là ok
    Feb 2006
    cái tool này mò mò cũng hay lắm à , nó làm được nhiều cái mà box không làm được đó , support file flash tiếng việt cũng cực nhanh .
    Thành viên chính thức langtu028's Avatar
    sao hok dowload đc các anh nhỉ
    (¯`'•.¸(¯`'•.¸langtu028 ¸.•'´¯)¸.•'´¯)
    Feb 2006
    Thành viên mới hoobin's Avatar
    Dec 2008
    sao em dowload về mà toàn tiếng trung quốc không hà sao biết nút nào mà bấm anh cho xin bản khác đi với lại cho em hỏi tool này chạy tiếng việt có được không nếu được thì chỉ cho em một tí nghe cảm ơn anh nhiều lắm
  9. #8
    Thành viên chính thức huynhthanhthi's Avatar
    Lightbulb Seking
    Trích Được post bởi hoobin Xem bài viết
    Lên đây 4shared.com - online file sharing and storage - download SeKing3.0.6.9_English.rar lấy phiên bản mới nhất & english nè you!!!!!!!
    Niềm_Đam_Mê_Táo
  10. ( huynhthanhthi ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    coniu (29-11-2009), tamhuyvalid (16-09-2009)
  11. #9
    Thành viên mới xungiphone's Avatar
    ai chi ca'ch ca`i luon di sao cai no doi ji lung tung the
  12. #10
    Nhà lá kế nhà tường
    anh kha sao em vào, nhưng nó lại là chữ tàu không vậy anh.
    ĐT: 0985676369 thanh@việt
  1. Sony Ericsson Easy Hardware Tool
    By Hoang Thong Mobile in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 08-03-2010, 12:59
  2. Hot hot-Sony Ericsson Hardware fix up Tool
    By TuấnPhát_GSM in forum Phần mềm Sony-Ericsson
    Bài viết cuối: 24-12-2009, 20:51
  3. Very Hot Sony Ericsson Hardware fix up Tool.v6.0
    By phúlộc_gsm in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 08-07-2009, 11:58
  4. Very Hot Sony Ericsson Hardware fix up Tool
    By Hoang Thong Mobile in forum Phần mềm Sony-Ericsson
    Bài viết cuối: 03-07-2008, 01:24
  5. Sony Ericsson Hardware Tool !!!
    By TuongBinhThuan™ in forum SONY-ERICSSON
    Bài viết cuối: 14-01-2008, 11:40
