Kết quả 1 tới 10 của 14
    Thành viên chính thức nguyendong_mobi's Avatar
    Mặc định 2700 flash mất nguồn
    mình mới nhận 2700c mở nguồn lên chớp tắt đã backup rồi flash xong không đồng bộ được giờ mất nguồn luôn đây là log của em nó nhờ ae xem dùm thanks all
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C0859FE9
    Using device: HTI, FW ver: 00.24, SN: 00006D78
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 05E000175F728E561C2AFDD7ED08B6C049BE187A
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung ] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 18.750 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 17.829 s
    Processing PPM file: rm561__09.98.ppm_v
    [BB5,BB5 ALGORITHM] size: 6.90 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 28.156 s
    NOR: OK
    NOR: OK
    Programming completed in 27.922 s
    Processing CNT file: rm561__09.98.image_v_blac
    [BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 1 min 1.485 s
    NOR: OK
    NOR: OK
    Programming completed in 55.078 s
    Total time for flashing process(boot+erase+write) was 5 min 59.953 s
    Thành viên mới luongvansang's Avatar
    Nov 2010
    đem qua box khác múc tiếp a zai....cho cái ver đụng nóc đi a....
    Moderator TÚ CÒI's Avatar
    hà nội
    ver này đụng nóc rồi
    nếu read full bằng ATF hoặc Cyclon thì xóa full nạp lại coi sao
    tốt nhất cho box khác flat chứ mx flat kém lắm
    hwk rồi mt thì không boot được flash bằng dây usb cũng vậy
    Thành viên tích cực SỸ HẢI_mobile's Avatar
    tháo màn hình +camera ra chạy lại coi sao
    sỹ Hải_mobile
    Thành viên chính thức thanhloan182's Avatar
    Bạn làm theo cách này có ok không
    Cứu BB5 ngủ sau khi Flash
    ACE làm phần mềm chắc hẳn ai cũng gặp ko chỉ 1 lần máy bb5 đang lên nguồn bình thường chỉ bị 1 lỗi nhỏ nào đó mà phải chạy lại phần mềm như không cập nhật danh sách nhạc,không có tiếng việt,hoặc chớp tắt...sau khi chạy xong thì máy ngủ luôn,chạy đi chạy lại vẫn vậy.Nếu có backup đầy đủ thì ko sao,ko có backup thì quả là hơi run
    Có nhiều cách để cứu máy như thay sợi cáp khác và chạy lại,chạy bằng usb,chạy từng file,xóa full nạp lại(nếu có backup đầy đủ)
    Ở đây mình muốn chia sẻ với mọi người cách mà mình vẫn thường làm là sử dụng chức năng BB5 SW Downgrade Fix bằng mxkey,chắc hẳn là ai cũng biết đây là chức năng sửa lỗi khi hạ ver bb5 mà quên không ấn vào ô Downgrade, nhưng ngay cả khi các bạn không Downgrade cũng có thể sử dụng chức năng này bình thường,miễn sao là máy lên được nguồn
    http://i1182.photobucket.com/albums/...kodongbodc.jpg
    Còn đây là hình ảnh sửa lỗi bằng mxkey
    Nov 2010
    con này là SL3 mà bạn
    bạn downgrade thì sao mà lên nguồn được
    thanks ae đã chia sẻ để mình làm tiếp có gì báo ae sau
    gỡ camera và màn hình ra flash not ok chắc phải làm cứng rồi ae cho thêm ý kiến thanks
    Feb 2008
    lâm đồng
    dùng phonix đi bạn ok đó
  1. Trả lời: 23
    Bài viết cuối: 18-07-2013, 11:24
  2. Trả lời: 7
    Bài viết cuối: 02-05-2013, 21:56
  3. thay flash 2700
    By trunghaumobile912 in forum BB5
    Bài viết cuối: 24-10-2012, 17:49
  4. 2700 flash báo lỗi
    By vanchien89 in forum BB5
    Trả lời: 20
    Bài viết cuối: 16-03-2012, 17:19
  5. 2700 flash mât nguồn
    By ngocthu2208 in forum BB5
    Trả lời: 25
    Bài viết cuối: 17-06-2011, 19:23
