    Thành viên chính thức gialong113's Avatar
    Mar 2010
    Mặc định 7610s cần giúp
    em có một con 7610s của thằng em nó chạy pm bằng phonix rồi mất điện đột ngột và mất nguồn xong mang qua cho em.em lấy mx box chạy usb được nửa chừng thì như này:
    MXKEY [MxKey HTI FLASHER INTERFACE 1], SN: C0853805
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.70
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    Processing MCU file: rm354__07.23.mcusw
    [BB5,BB5 ALGORITHM] size: 21.36 MB
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3906ECD8
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT EM0 ID: 00000295
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0B8000170FF05850B5880D9C5528FB8D7F5183FC
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4AD00 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59700 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 10F6269E
    Verifying communication to device OK.
    Erase size: 22.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.390 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.391 s
    CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.219 s
    CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.047 s
    CMT FLASH,NOR area [00140000-014DFFFF] erased in 1 min 5.344 s
    CMT FLASH,NOR area [014E0000-0167FFFF] erased in 5.500 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: B8DE3D7D [RAP Certificate 113 v1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    Error while programming [00] at 0x003F0400, Result: 0000
    mong các bác xem và giúp đỡ em với....em cảm ơn ạ
    Moderator TÚ CÒI's Avatar
    hà nội
    để 24h
    mang qua box khác flat
    mx flat ko ra gi đâu nhé
    Oct 2010
    cái này chay từng file nha ban mình da chay ok cả chuc cây rồi
    Thành viên tích cực thuy1986's Avatar
    mình cũng bị nhiều cây như vậy rùi chạy lại bằng ATF ok hết mà ?
    May 2011
    Hà Nội City
    lấy ver cao hơn ver cũ đã xhạy chạy lại + factoryset là done ấy mà
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    Lấy boxx khác flash ver cao hơn làm ok thôi
    Thành viên chính thức h_giang's Avatar
    Dec 2008
    nhưng con bị như vậy em hay chạy bằng cáp đa năng.
    Hạnh phúc là sự im lặng của nỗi đau và khi nỗi đau lên tiếng thì hạnh phúc không còn tồn tại.
    V.I.P ThanhHai_GSM's Avatar
    trương hợp vậy có ATF flash cái là done
    Mar 2010
    thanks các anh nhé.em làm được rồi ạ.hóa ra em chạy bằng usb mà không để ý là máy hết pin.em thay pin mới flash ok rồi ạ.thanks các anh ạ
  1. 7610s mic cần giúp đỡ
    By KIÊN NGUYỄN MOBILE in forum BB5
    Bài viết cuối: 23-08-2011, 10:38
  2. 7610s mất míc cần giúp
    By blackeyexx in forum BB5
    Bài viết cuối: 06-01-2011, 13:15
  3. giúp e con 7610s này với ạ.^:)^
    By lauxanh in forum DCT4 - WD2
    Bài viết cuối: 25-05-2010, 21:52
  4. Trả lời: 1
    Bài viết cuối: 28-04-2010, 01:21
  5. 7610s...mất mic xin giúp đỡ
    By chuminhtruong2009 in forum BB5
    Bài viết cuối: 06-01-2010, 08:41
