máy đang dùng mất nguồn, đưa vào box check lên nguồn bình thường
đã flash lại ok hết vẫn vậy, log đây:
Version from phone: 510.21.009
Version from file: 510.21.009
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0853831
Using device: HTI, FW ver: 00.24, SN: 00003D39
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35485502815785_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 07C00110737000526B7B61865532E5B49E8FADA8
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.24.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.24.0 revision: 2.0 size: 0x87D1A
CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
Processing MCU file: rm346_510.21.009_prd.c00
[BB5,XSR 1.5] size: 67.83 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 122.56 MB
CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 52570A20 [RAP Certificate 101 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
NAND: OK
Programming completed in 3 min 12.984 s
Processing PPM file: rm346_510.21.009_prd.v29
[BB5,XSR 1.5] size: 22.51 MB
Erase size: 33.56 MB
CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
NAND: OK
CMT SOS+ROFX block sent
NAND: OK
Programming completed in 1 min 6.672 s
Processing CNT file: RM346_ENO_0741.10_08wk42.a36.fpsx
[BB5,XSR 1.5] size: 1.53 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
Erase size: 64 KB
NAND: OK
CMT SOS*ENO block sent
NAND: OK
Programming completed in 5.063 s
Processing CNT file: leevi_erase_y_drive.fpsx
[BB5,XSR 1.5] size: 244 Bytes
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 400C192101031105
Erase size: 1.62 MB
CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF]
NAND: OK
Programming completed in 0.000 s
Processing CNT file: rm346_510.21.009.07U
[BB5,XSR 1.5] size: 21.06 MB
Erase size: 64 KB
NAND: OK
NAND: OK
Programming completed in 1 min 3.265 s
Total time for flashing process(boot+erase+write) was 5 min 43.000 s
Phone type: RM-346 (Nokia E71)
SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia
Imei plain: 35485502815785-6
Product code: 0560655
Battery voltage: 4880 mV, current: 4 mA
Language Pack:
- not available.
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354855028157856
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
đã làm chân đóng lại cặp nguồn, cpu, flash vẫn k ok
lâu lâu cũng mở lên nguồn đc dùng bình thường, nhưng tắt khởi động lại k đc
AE đã gặp qua bệnh này xin giúp cách khắc phục
mình nghĩ bị đứt đường nào đó
thank!
