Kết quả 1 tới 4 của 4
    Thành viên chính thức mjnhtuan123's Avatar
    Nov 2010
    Mặc định x2 01 mất nguồn xin giúp
    tình trạng máy rơi nước.em đã vê sinh sấy lai.em lắc lai ic nguồn thì lên nguồn.nhưng chỉ rung 1 cái rồi báo pin yếu rồi tắt nguồn lun,flas thì log đep ok,đã đóng lai ic nguồn.vân not ok.tháo camera.ic butool.1 bênh nữa là mất đèn nửa chứ,em tháo bỏ ic đèn lun tình trang vẫn như cũ lên rồi tắt.em đã khò nóng hết mian rồi,not ok,ae xin giúp.đây la log của nó//MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0855BFC
    Connection status: EHCI:HUB:USB 2.00 (High-speed)
    Driver: nmwcdc, ver: 7.1.32.70
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Processing MCU file: rm709__08.63.mcusw
    [BB5,XSR 1.6] size: 26.59 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    NOR pagesize not defined, no changes will be made to CNT.
    Battery voltage: 2148 mV
    Warning battery voltage is less, phone might not detected after flash !
    Phone type: RM-709 (Nokia X2-01)
    Product code: 059F8F0
    SW version: V 08.63 - 25-03-11 - RM-709 - (c) Nokia
    LanguagePkg version: 3 - 25-03-11 - RM-709 - (c) Nokia - V
    Version from phone: 08.63
    Version from file: 08.63
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2B160F7A
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 00000000008C8FD3B715C97FA951DF8C9AB56E0E
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT
    Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
    Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 33.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
    CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
    CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT ADA block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 37955B6F [] sent
    CMT UPDAPP block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT ISA+DYNSW block sent
    Programming completed in 11.360 s
    Processing PPM file: rm709__08.63.ppm_v
    [BB5,XSR 1.6] size: 6.80 MB
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
    Programming completed in 2.656 s
    Processing CNT file: rm709__08.63.image_v_059C2X8
    [BB5,XSR 1.6] size: 28.76 MB
    Erase size: 75.31 MB
    CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
    Programming completed in 11.641 s
    Total time for flashing process(boot+erase+write) was 43.891 s
    Device connected: nmwcdc\X2-01 USB Phonet, PORT_ID: 1D1DD051
    Verifying communication to device OK.
    Phone type: RM-709 (X2-01)
    SW version: V 08.63 25-03-11 RM-709 (c) Nokia
    Imei plain: 35741004068236-1
    Battery voltage: 2148 mV, current: 1 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 357410040682361
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Market items is empty, please select the correct products path !
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.282 s
    Thủ đô Hà Nội
    Thay thế con V2301 gần chân Pin là ok
    p/s : các trang upload ảnh đang quá tải nên ko thể up ảnh cụ thể được.chúc bạn thành công
    Nov 2010
    Trích Được post bởi minhchienmobi Xem bài viết
    e đã thay v2301 rồi not ok anh chiến ơi.ae giúp em xiu
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    Thay Ic nguồn khác đi bạn hiền
