Kết quả 1 tới 10 của 10
    Thành viên tích cực duchung038's Avatar
    May 2011
    Mặc định anh nào có kinh nghiệm xin giúp em 31110c lỗi phần mềm.
    tình hình là em có con 3110c chạy phàn mềm song là không hỗ trợ bọ sạc.truoc khi chưa chạy thì sạc ok. anh nào sem em họ cái log này nhe?cách sửa như thế nào?mx-box e chưa biết qua>mong anh em chỉ dẫn MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0849028
    Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.70
    Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
    Processing MCU file: rm237__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 472EEA3
    CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
    CMT EM0 ID: 00000232
    CMT EM1 ID: 00000353
    CMT PUBLIC ID: 1D90011275487E56AF00C1FA4ACB1B7E978FB9FF
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM ID: 191EC665DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x38C0 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x3DFC0 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x4BF80 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 10688386
    Verifying communication to device OK.
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.891 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.875 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 2.750 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 2.750 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 6.360 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 7.640 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 1 min 30.422 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.797 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.813 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: C0E691EA [RAP Certificate 66 v2] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    CMT PMM_CONF block sent
    CMT SBIF_CONF block sent
    Programming completed in 54.500 s
    Processing PPM file: rm237__07.30.ppm_b
    [BB5,BB5 ALGORITHM] size: 2.89 MB
    Erase size: 4.62 MB
    CMT FLASH,NOR area [01080000-0151FFFF] erased in 30.938 s
    Programming completed in 11.016 s
    Processing CNT file: rm237__07.30.image_b_era_pl2_128
    [BB5,BB5 ALGORITHM] page size: 64 K size: 4.82 MB
    Erase size: 10.75 MB
    CMT FLASH,NOR area [01520000-01FDFFFF] erased in 1 min 26.375 s
    UCP page size is 128 K.
    Programming completed in 17.969 s
    Total time for flashing process(boot+erase+write) was 5 min 44.250 s
    Device connected: nmwcdc\Nokia 3110 classic USB Phonet, PORT_ID: 30D553EA
    Phone type: RM-237 (Nokia 3110c)
    SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
    Imei plain: 35934302895909-7
    Battery voltage: 3853 mV, current: 137 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY invalid!
    - WD timer enabled, phone will reboot itself after 3 min.
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 359343028959097
    Version: SIMLOCK SERVER VERSION 63
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Writing PM from Node ...
    chú ý port bài đúng nơi quy định
    đã move
    V.I.P ThanhHai_GSM's Avatar
    repair SD > sx4 > pm 1, 309 = done
    Vi phạm nội quy tuananh_mobile1990's Avatar
    Apr 2011
    anh em qua vietfone di co hét
    chú ý lời ăn tiếng nói nhé
    V.I.P anhvanmobi's Avatar
    lỗi là ở đây
    HTML Code:
    làm như Mod Thanhhai đi bạn. Chúc thành công
    May 2011
    mx-Box không thấy o đâu anh ah/anh chi dẫn chi tiêt bằng mx-box không anh>
    Moderator TÚ CÒI's Avatar
    hà nội
    Trích Được post bởi duchung038 Xem bài viết
    qua yahoo mình làm cho
    May 2011
    đã làm ok.thay con trỏ 47k ok .nhưng thật lạ.trước đó chưa chạy nó sạc được,chạy song không sạc được,đã thay tận 4 con trở mới hoàn thành,cảm ơn anh em
    Thành viên tích cực gamoi.gsm's Avatar
    Jul 2011
    có chém thì chém vừa vừa thôi chư a sao chém kinh thế?
    thay trở 4k7 ok mới sợ chứ. vãi....
    yah:Gamoi_gsm@yahoo.com.vn
    hà nội
    sửa lỗi đi bạn
    làm cứng làm chi
    TP Hồ Chí Minh
    Trích Được post bởi gamoi.gsm Xem bài viết
    cái này anh nên đọc kỹ tiêu đề của chú thớt nhé.
    pan này chú thớt bị 2 bệnh.
    1. không hỗ trợ bộ sạc.
    2. SUPERDONGLE_KEY invalid!
    mục 2 chú thớt làm xong từ hồi nào.
    còn mục 1 chú thớt vừa làm xong nên báo lên.
    Đừng vì chú thớt sơ xuất mà chém nhé.
    Mod nào ghé qua Close Topic dùm tránh Spam
  1. Cần Tuyển 2 kỹ thuật phần cứng có kinh nghiệm 3 năm trở lên.
    By saigonmobile in forum TUYỂN DỤNG VIỆC LÀM
    Bài viết cuối: 13-01-2015, 07:47
  2. bác nào có kinh nghiệm sửa chữa phần cứng máy tàu giúp e phát
    By phamvanhuu in forum Sửa chữa phần cứng
    Trả lời: 13
    Bài viết cuối: 24-07-2014, 14:21
  3. Trả lời: 10
    Bài viết cuối: 23-11-2011, 18:01
  4. Trả lời: 7
    Bài viết cuối: 07-09-2011, 21:50
  5. mot so kinh nghiệm ve phần mèm tq
    By nguyenhoangvp in forum Máy Trung Quốc
    Bài viết cuối: 28-10-2009, 15:58
