Kết quả 1 tới 10 của 11
    Thành viên chính thức HQuangmobile's Avatar
    Nov 2011
    Mặc định n72 rm 180 nạp flash báo lỗi
    nhờ ae xem giúp log
    ersion from phone: 5.0819.4.0.1
    Version from file: 50819401.C0
    MXKEY Serial: [FT SCR2000 0] - C0817F31
    Driver: UFS2XX, ver: 1.6.6.0 , NTMP ver: 1.6.6.1
    Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011)
    Reading Important data ...
    Reading RPL backup ...
    Reading Secure Storage ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    APE Data :
    SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1]
    ASIC MODE ID: 00
    PUBLIC ID: 4E905A7C9ACF4B56DA4C74657F9728650DE4FAB2
    ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000
    ROM ID: AB5E4ADB27A06946
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01]
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 165001185E4F5151A12DBC4E1B4D9BC531DB0468
    ASIC MODE ID: 00
    ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14
    ROM ID: F28A211FCEA7B19D
    SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00
    Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200
    FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D
    TransmissionMode: DDR&TX2
    SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
    Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
    loader not responding (0910000000B172)
    Read Certificate failed.
    NPC_DATA is empty.
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to ".rpl"
    Processing MCU file: RM180_50819401.C0
    [BB5,BB5 ALGORITHM,BB5,OMAP1610 GBBM-1.8.1 ALG] size: 28.69 MB
    Supported Ids: 0003192101012200, 000C192101012200
    Supported Ids: 17100701, 17100702
    APE Data :
    ASIC MODE ID: 00
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Task failed at (08000006)!!!
    Last RX buffer: 09 10 00 00 00 B1 72
    Nov 2011
    ae có file cao nhất cho mình xin luôn nhé
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    Mx key là chúa gây ra lổi này. bạn đưa qua box khác thử xem đồng thời kiểm tra luôn tx pinout nhé
    V.I.P ThanhHai_GSM's Avatar
    không phải do file
    các máy bb5 chạy điều hành SYMBIAN chỉ hwk chạy là chuẩn nhất
    Nov 2011
    chay jaf có ổn không mấy huynh
    Thành viên kỳ cựu setot_thoi's Avatar
    Sóc Trăng
    Trích Được post bởi HQuangmobile Xem bài viết
    JAF cũng ok . cũng tùy hứng nên test thử
    MẩnMobile .Y/H : Jimmyphong10
    Thành viên tích cực Phungmobi's Avatar
    Sep 2010
    trước mình chạy con 3110c bên mx nó chữ ngược không vào phần cài đặt được....đem qua hwk ok.....bạn chạy bên hwk xem thử
    buôn ma thuột,daklak....y/h : vangtrangcodon_tny145
    Thành viên kỳ cựu phamdienmobile's Avatar
    biên hòa - đồng nai
    HWK trị căn bệnh này ok nha bạn ( đã test nhiều )
    Nov 2011
    thank minh nạp jaf ok nhưng jo thì báo sim card not valid
    Nov 2010
    nạp xong unlock cho em nó phát đi anh
  1. VolcanoBox2.7.6 Beta SPD Android Read Flash & Write Flash Much More Improved
    Bài viết cuối: 28-07-2014, 09:14
  2. Trả lời: 7
    Bài viết cuối: 18-10-2013, 09:52
  3. Trả lời: 7
    Bài viết cuối: 07-09-2012, 09:54
  4. Trả lời: 2
    Bài viết cuối: 06-01-2010, 23:17
  5. Trả lời: 3
    Bài viết cuối: 22-06-2009, 17:00
