    Thành viên tích cực minhtu2326's Avatar
    Mặc định xin hướng dẫn chạy lg kp500 bằng cáp usb
    bác nào biết chạy lg bằng cáp usb hướng dẫn cho em chi tiết với em xin cảm ơn nhiều
    V.I.P DAKLAK-GSM's Avatar
    Aug 2010
  3. ( DAKLAK-GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ducthong.qn (12-12-2014)
    gúp em với các đại ka ơi em đang cần gấp quá
    Moderator nhotrung_bn's Avatar
    266-Phố Mới Thị TRấn Hồ-Thuận Thành-Bắc Ninh
    Lang thang lụm lặt được cái này và đã test ok nên post lên cho ACE tham khảo nghen.
    Download File KP500_10N_Firmware
    Download File SETUP_GSMULTI_V30 + KP500 dll file
    1) INSTALL THE SOFTWARE AND DRIVERS - DRIVERS WORKS ONLY ON XP WINDOWS
    (Don't connect your phone on computer yet)
    Downloaded files should be un-ziped (I unziped them in one folder which i made it on desktop)
    You got next files:
    program
    - SETUP_GSMULTI_V30
    - KP500_081002.dll
    firmware
    - KP500AT-00-V10n-CIS-XXX-DEC-17-2008
    - KP500AT-00-V10n-CIS-XXX-DEC-17-2008.bin.mbn
    2) Install GSMULTI (SETUP_GSMULTI_V30). The icon will shows on your desktop otherwise the program install on C disk, folder GSMULTI
    - start GSMULTI
    - select: Settings/Configuration
    - put .dll file and firmware file in and choose USB then click OK and close program
    3) Install DRIVERS (INFINEON and TI_NEPTUNE)
    Drivers to be found in install folder of GSMMULTI program. My path is C:\GSMULTI\UsbDrivers
    - First install INFINEON
    - Second TI_NEPTUNE
    4) PREPARE AND CONNECT YOUR PHONE
    - Now u take a phone (shut it down) and remove, BATTERY, SIM CARD and MEMORY CARD then
    - conect it with your USB cable to computer (I suggest that u connect only in one USB port on computer)
    - wait about one minute that comuputer recognize new device
    5) USBMap PROGRAM
    - Run program USBMap_V01 (which can be found in C:\GSMULTI)
    - Select INFINEON and then click MAPPING START
    -WAIT (about one minute) that USBMAP will find USB port where is the phone connected
    - When the port will be found click on (select it) and press SAVE&EXIT
    6) MAIN PART - FLASHING
    - Run GSMULTI program (shourtcut is in your desktop)
    - Check if settings/configuration are the same like we set it before (otherwise look step 2.)
    - Now its everything ready to start flashing
    - Check MODEL and SW VERSION and if that is correct just click START and wait until the program finished
    - And voila, here we have a new firmware version
    Test flash Kp500 mất cỡ khoảng 10phút là ok bằng cáp USB.
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    anh làm theo như hưỡng dẫn ở đây bài này là em suy tầm trên mạng nhưng mà người ta đã test ok rùi lên anh cú mạnh tay mà flash
    NHOTRUNG_BN ADD: 266 Phố Mới-TTH-TT-BN
    Nhận unlock-Bẻ Khóa-Nạp Phần mềm
    Repair boot-unbrick all sam sung-sony-LG-HTC...
  6. ( nhotrung_bn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Moderator DuyQNgãi's Avatar
    Quảng Ngãi City
    Firmware:Kp500_tv
    Tool & File DLL:MultiGSM ver 3.0 + kp500 .dll file
  8. #6
    V.I.P minhphuc's Avatar
    Apr 2006
    trước khi hỏi nên tìm kiếm trước nha đã có bài hướng dẫn rồi nè
    xin hương dẫn chạy lg kp500 bằng tool chi tiết
  1. chế sạc kp500
    By anhtuan.tran88 in forum LG 2G
    Bài viết cuối: 01-04-2013, 08:18
  2. xin hương dẫn chạy lg kp500 bằng tool chi tiết
    By minhtu2326 in forum Phần mềm và các mã lệnh
    Bài viết cuối: 26-10-2011, 20:33
  3. lG kp500 chạm xin giúp
    By sydungdtdd in forum LG Qualcomm
    Bài viết cuối: 25-09-2011, 16:33
  4. xin giúp tool chạy phần mềm lg kp500
    By haianh_m in forum LG 3G
    Bài viết cuối: 26-06-2011, 09:24
  5. Vygis nạp KP500 qua chậm
    By phucuongmobile in forum VygisToolbox
    Bài viết cuối: 23-11-2009, 15:39
