Kết quả 1 tới 3 của 3
    Thành viên mới mrcas's Avatar
    Jun 2011
    Thumbs up Help: Giúp đỡ phone Nokia 6700 Classic không khởi động được
    Con phone của em bị tình trạng Mở nguồn lên, bàn phím sáng. 1 lúc sau tắt và phone không thể khởi động được. Em đã dùng Phoenix Flash lại firmware và vẫn thế. Dưới đây là log của phoenix:
    Code:
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    Loading secondary boot code: 15168 bytes
    Secondary boot loaded
    BB Asic Index is: 00
    Asic ID is: 000000030000022600010007600C192102011104
    EM Asic ID is: 00000C34
    EM Asic ID is: 00000C30
    Public ID is: 0C60001645480E4934A2AFF045E588DDD37B7071
    Asic Mode ID: 00
    Hash: 25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    Device type is: 05
    Device Index is: 00
    Manufacturer code: 0000
    Device ID: 0000
    Extended device ID: 0000
    Revision ID: 0000
    Device type is: 04
    Device Index is: 00
    Manufacturer code: FFFF
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 00
    Device ID: 0000
    Revision ID: 0000
    Device type is: 00
    Device Index is: 01
    Device ID: 0001
    Revision ID: 0000
    Device type is: 03
    Device Index is: 00
    Manufacturer code: 0098
    Device ID: 0040
    Revision ID: 0031
    Loading update server code: 812840 bytes
    Update server loaded
    Asic CMT: Start programming 61183 KB...
    Asic CMT: Programming data sent: 0%
    Asic CMT: Programming data sent: 10%
    Asic CMT: Programming data sent: 20%
    Asic CMT: Programming data sent: 30%
    Asic CMT: Programming data sent: 40%
    Asic CMT: Programming data sent: 50%
    Asic CMT: Programming data sent: 60%
    Asic CMT: Programming data sent: 70%
    Asic CMT: Programming data sent: 80%
    Asic CMT: Programming data sent: 90%
    Asic CMT: Programming data sent: 100%
    Programming complete
    Asic CMT: Verifying communication to device...
    Phone flashing completed. Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Communication verified
    Product code changed
    Doing factorysets
    Factorysets complete
    Reading Dynamic Camera Configuration ID 1
    Updating configuration of camera with ID 1
    Dynamic Camera Configuration updating failed: 0x84167501 - AudioVisual: No configuration file matching the camera name string ISL2TI020000093E2F30 was found.
    Loading default data to phone
    Getting Data Package
    Reading product state
    Starting backup/restore sub-procedure: data item pre-delay
    data item pre-delay
    data item pre-delay
    Sub-procedure completed: Succeeded., result code: 0
    Starting to backup/restore data item: ProductProfile, version: 1.1
    Data Item backup/restore completed: Succeeded., result code: 0
    Starting backup/restore sub-procedure: data item post-delay
    data item pre-delay
    data item pre-delay
    Starting to backup/restore data item: ISSVariantActivator, version: 1.0
    Backup/restore result: 0 out of 2 items were not backed up
    Default data loading complete
    Stopping all operations, returning phone to default mode
    All operations completed
    Firmware updating succeeded.
    Tuy nhiên khi flash xong phone vẫn không thể khởi động được. Dùng JAF flash thì bị báo là nhận diện được phone nhưng không thể flash. Đã đem ra VTA và họ cũng bó tay trả lại.
    Giúp em với.
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    bạn là người dùng xin vui lòng đem ra tiệm sửa tin cậy nhờ người ta giúp. thanks
    Nov 2010
    lại thêm 1 em yêu khoa học nữa
    đem ra tiệm cho nhanh nha bạn
  1. Cần võ zin 6700 classic.
    By vonhubao in forum ĐIỆN THOẠI & LINH KIỆN
    Bài viết cuối: 13-05-2014, 13:01
  2. Cần giúp 6700 classic ic thẻ nhớ !
    By CungCầu8888 in forum DCT4 - WD2
    Bài viết cuối: 28-11-2013, 10:55
  3. 6700 classic mất loa ngoài cần giúp gấp
    By tuyen_mobile1709 in forum BB5
    Bài viết cuối: 29-08-2012, 22:14
  4. 6700 classic rm-470 cần dúp
    By ThùyThương_GSM in forum BB5
    Bài viết cuối: 02-06-2012, 11:12
  5. 6700 classic lỗi camera kỳ quái
    By duyhieu85 in forum BB5
    Bài viết cuối: 14-05-2012, 15:27
