    Thành viên mới quyhoi1507's Avatar
    Dec 2010
    Mặc định X2-00 mất nguồn, mong ae giúp
    e mới nhận của khách X2-00 đem đến trong trạng thái mất nguồn. kẹp dòng thì thấy eckkim dao động. đã check FW nhờ ae coi dùmMXKEY Serial: [FT SCR2000 0] - C0841425
    Driver: NMWCD, ver: 7.1.32.67
    Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011)
    Waiting for USB device ...
    Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2331C855
    CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
    CMT EM0 ID: 00005361
    CMT PUBLIC ID: 0000000000C0909BD6E6FBB5AD06057C07EC5C4A
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
    CMT ROM ID: DE56D582BDDE7A3A
    Loading CMT secondary boot code
    SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    Secondary boot loaded.
    FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT
    FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT
    FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT
    ALG [35]: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
    Original Imei: 35699004049860
    Original Product code: 059C4G1
    Bluetooth ID: D45D42827F02
    SIMLOCK PA identifier:
    [0] PA_SL3
    Reading CMT HWC (0xD4 bytes).
    Device found: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 1FA68464
    Verifying communication to device OK.
    Phone Type: RM-618 (Nokia X2-00)
    SW Version: V 04.90 28-09-10 RM-618 (c) Nokia
    Imei plain: 35699004049860-4
    Product Code: 059C4G1
    Battery voltage: 4044 mV, current: 1 mA
    Language Pack:
    - not available.
    Detected as PA_SL3 phone.
    - Avoid SW Downgrade & manual erase to this phone !
    SIMLOCK seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356990040498604
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Market items is empty, please select the correct products path !
    em đã làm CPU rùi vẫn vậy. Mong ae ai biết chỉ dùm.thanks
    chú ý : không lập 2 topic giống nhau
    Moderator Dong_Mobile's Avatar
    Nov 2010
    Log đẹp check con dao đông xem thế nào anh.rồi đến con nguồn
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Ẹc...máy vẫn sống bình thường,dòng này ko kẹp nguồn đc,cho pin vào bạn
    V.I.P anhvanmobi's Avatar
    Con này kẹp nguồn chỉ rung 1 cái là tắt luôn thôi. Bạn lắp pin thử xem sao nhé
    Moderator DuyQNgãi's Avatar
    Quảng Ngãi City
    kiểm tra lại màng hình xem anh
    Thành viên mới phuongan1603's Avatar
    máy vẫn lên nhưng kẹp nguồn không nhận nắp pin vô ok luôn
    {-:-_-:-}Quên Sao được những ngày Đau khổ............Khổ đau này nhất định rùi cũng Qua{-:-_-:-}
    Thành viên chính thức bonmobile89's Avatar
    Dec 2010
    chắc máy hết pin mất nguồn ý mà . kiễm tra lại cục pin xem anh
    Dec 2010
    thanks ! ae đã giúp đỡ e làm được rồi, dòng này củ chuối thật, phải dùng pin mới thử được
    Thành viên chính thức Phước_mobile's Avatar
    Jul 2011
    dòng này muốn kẹp nguồn cũng đơn giản mà bạn.chỉ cần lấy cái chấu pin rồi hàn 2 dây vào âm dương rồi bỏ vào máy cấp nguồn là lên vi vu thôi ^^
    Mọi Khó Khăn Chỉ Là Thử Thách Để Ta Vượt Qua.
  1. c1 01 mất nguồn mong a e giúp
    By levanhieu@ in forum DCT4 - WD2
    Bài viết cuối: 30-07-2013, 10:30
  2. Trả lời: 12
    Bài viết cuối: 30-09-2012, 04:37
  3. Log N72 mất nguồn mong ae giúp đỡ
    By Viola2009 in forum BB5
    Bài viết cuối: 14-04-2009, 15:43
  4. V3 châp nguồn mong các anh giúp em
    By tuan1102 in forum P2K Series
    Bài viết cuối: 29-03-2009, 20:47
