ae cho hỏi dòng chip xgold này là dòng dct4 hay bb5 vậy !
				 c2_ 00 mã bảo vệ cần giúp !
				DCT4
Cho vào mx tích vào DCT4-->X-gorl-->full factory=ok
				nó là dtc4 bạn ơi
				MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0853672
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.70
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2BED0384
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.44
EBL version : Quantum_Bootloader_10.44_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbps
Flash ID: 0089 8982 [Intel NU48F512,512 Mbits]
Device connected: nmwcdc\Nokia C2-00 USB Phonet, PORT_ID: 280CAFC3
Verifying communication to device...
ERROR: Could not verify communication !
mình bus chest nó báo như trên còn fatory nó báo feair ae xem giúp !
				NK module version: 1.23
NK applet version: 00.20
NK module ready.
Market items is empty, please select the correct products path !
Please "Scan" or "BUS check" before any operation ...
FULL FACTORY... Failed! (03E5)
Completed in 1 min 0.016 s
				bạn chạy cáp đa năng thì chỉnh bis sang mức khác rồi flash lại
				cho vào phoenix quất phát ok luôn
				cho vo mx,chọn file MCU,tích xgool=> buschk=>factory=>ok
CHDT- QUANGKHAIappstore 0963.290.007
				Dòng x-gold tích chọn file mcu busk check ,scan => full factory là ok.
