1280 máy đang sử dụng. rồi mất nguồn luôn,
-em đã làm upp lại, flash thì log thê này
-nhờ ae giup , thank all
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855D93
Using device: HTI, FW ver: 00.24, SN: 0000B3E9
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Do not disconnect or abort this operation otherwise phone will be damaged.
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.19
EBL version : Default_RAM_Bootloader
Set baud rate to: 921.60 Kbps
Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
Processing file: rm647_005.800
Downloading item CODE:hw_b2_rm647_r05.800.fls, num block: 3, size: 3.99 MB
Erasing area 0x00800000-0x00A0FFFE ...OK
Programming completed in 42.141 s
Erasing area 0x00C60000-0x00E4C2BE ...OK
Programming completed in 39.391 s
Erasing area 0x00FFC000-0x00FFC03E ...OK
Programming completed in 0.157 s
Checksum verified (0x6458)
Processing file: rm647_005.80mr
Downloading item CUST:hw_b2_rm647_005.80mr.fls, num block: 1, size: 1.10 MB
Erasing area 0x00210000-0x0032887E ...OK
Programming completed in 22.500 s
Checksum verified (0x78C4)
Processing file: rm6470_nai05.80mr
Downloading item CUST:hw_b2_rm6470_nai05.80mr.fls, num block: 1, size: 308.70 KB
Erasing area 0x00EB0000-0x00EFC5BE ...OK
Programming completed in 6.281 s
Checksum verified (0xF7FB)
Total time for flashing process(boot+erase+write) was 3 min 14.953 s
