máy đang sài rùi tự rưng mất nguồn flash lại bằng mx box ok nhưng chỉ sáng hai đèn hông rùi không lên nguồn Version from phone: 07.21
Version from file: 07.21
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C085C93E
Using device: HTI, FW ver: 00.24, SN: 00015BB8
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Reading RPL backup ...
Reading Phone IDs ...
ROM ID: 191EC665DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
eBB5ProtocolType: OLD
PUBLIC ID: 1F300214A6978B560198592C809C6DA1A6BB5671
PRIVATE ID: AF4E368542E7A67847E72DFCBAB85A85DDF6B6CB
productData saved.
Restarting phone ...
Reading Secure Storage ...
Reading Important data ...
Reading SIMLOCK data ...
Reading CERT data ...
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
TransmissionMode: 16Bit
CMT PAPUBKEYS HASH: 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
TransmissionMode: DDR&TX2
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Flash Imei: 35690103807138
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
SUPERDONGLE_KEY_DATA saved OK
CMLA_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
BB_DATA saved OK
RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35690103807138_BA CK.rpl"
Processing MCU file: rm217__07.21.mcusw
[BB5,BB5 ALGORITHM] size: 14.50 MB
Supported Ids: 0103192101001101, 010C192101001101
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Storing certificate [NPC, VARIANT, R&D] ...OK
Erase size: 16.37 MB
CMT FLASH,NOR area [00000000-000006BF]
CMT FLASH,NOR area [000006C0-0001FFFF]
CMT FLASH,NOR area [00020000-0007FFFF]
CMT FLASH,NOR area [00080000-000DFFFF]
CMT FLASH,NOR area [00100000-001FFFFF]
CMT FLASH,NOR area [00200000-0031FFFF]
CMT FLASH,NOR area [00320000-0105FFFF]
CMT FLASH,NOR area [01060000-01067FFF]
CMT FLASH,NOR area [01068000-0107FFFF]
erased in 44.750 s
Prog.status for Asic CMT ...
NOR: OK
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
CMT PMM_CONF block sent
CMT SBIF_CONF block sent
NOR: OK
Programming completed in 1 min 14.031 s
Processing PPM file: rm217__07.21.ppm_v
[BB5,BB5 ALGORITHM] size: 5.16 MB
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 5.50 MB
CMT FLASH,NOR area [01080000-015FFFFF]
erased in 15.656 s
NOR: OK
NOR: OK
Programming completed in 28.203 s
Processing CNT file: rm217__07.21.image_v_128
[BB5,BB5 ALGORITHM] page size: 128 K size: 6.26 MB
NOR page size in the phone is 128 K.
CMT Data :
EM0 ID: 00000232
EM1 ID: 00000353
ASIC MODE ID: 00
Erase size: 9.87 MB
CMT FLASH,NOR area [01600000-01FDFFFF]
erased in 28.906 s
NOR: OK
UCP page size is 128 K.
NOR: OK
Programming completed in 33.109 s
Total time for flashing process(boot+erase+write) was 4 min 33.766 s
Phone type: RM-217 (Nokia 6300)
SW version: V 07.21 05-11-08 RM-217 (c) Nokia.
Imei plain: 35690103807138-6
Product code: 0554579
Battery voltage: 3840 mV, current: 124 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 356901038071386
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 2.406 s
			 anh em sem giùm cái log 6300
