    Thành viên chính thức binhokls's Avatar
    May 2011
    Mặc định 1280 rớt đất mất nguồn xin giúp
    như tiêu đề thay nguồn , upp , màn hình cho vào MXKEY
    báo như này rồi đơ
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0860294
    Using device: HTI, FW ver: 00.24, SN: 0000C47F
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbps
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Processing file: rm647_006.520
    Downloading item CODE:hw_b2_rm647_r06.520.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 44.578 s
    Erasing area 0x00C60000-0x00E5943E ...OK
    Programming completed in 45.500 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.329 s
    Checksum mismatch: Phone calculated 0x392E, software calculated 0xA0A3
    Processing file: rm647_006.52el
    Downloading item CUST:hw_b2_rm647_006.52el.fls, num block: 1, size: 1.25 MB
    Erasing area 0x00210000-0x0035033E ...OK
    Programming completed in 27.781 s
    Checksum mismatch: Phone calculated 0x148E, software calculated 0x03AE
    Processing file: rm6470_nai06.52el
    Downloading item CUST:hw_b2_rm6470_nai06.52el.fls, num block: 1, size: 348.70 KB
    Erasing area 0x00EB0000-0x00F065BE ...OK
    Programming completed in 8.296 s
    Checksum verified (0xD1BD)
    Total time for flashing process(boot+erase+write) was 3 min 29.750 s
    May 2011
    Hà Nội City
    Lắc cho con Plash phát rùi chạy lại xem
    Moderator Dong_Mobile's Avatar
    Nov 2010
    mang qua HWK Flast lại thử xem rồi tính tiếp bạn
    May 2011
    lắc rồi vẫn vậy ai còn biết cách khác ko?
    May 2011
    hwk em vừa lấy đi đổi giờ chưa lấy dc
    May 2011
    ai có ver cao nhất 1280 cho em xin luôn
    May 2011
    cho vào chạy nó đơ khoảng 15p thì hiện lên phone not responding , please reset the phone manually then click "OK" to continue! ( ấn ok hay Cancel )
    Nov 2010
    nếu làm liều giờ thì múc con UPP thôi bạn.upp tích hợp cả nguồn+trung tần
    Apr 2011
    Trích Được post bởi Dong_Mobile Xem bài viết
    làm theo bác này xem xao nhé
    yahoo.minh_dinh_mobile
    LH.0962.131.123
  1. Trả lời: 1
    Bài viết cuối: 12-02-2014, 21:22
  2. Trả lời: 11
    Bài viết cuối: 11-02-2014, 15:37
  3. 1280 rớt nước mất nguồn cần giúp
    By NguyenThanh_BM in forum DCT4 - WD2
    Bài viết cuối: 28-10-2013, 16:38
  4. Xin giúp 1280 lỗi phím nguồn
    By pakchanghy in forum DCT4 - WD2
    Bài viết cuối: 22-01-2013, 11:30
  5. 1280 mất nguồn cần giúp
    By ĐôngSơn_mobile in forum DCT4 - WD2
    Bài viết cuối: 12-09-2011, 08:54
