các bạn cho mình hỏi nokia C2-02 ( RM-692 ) có chạy tiếng việt được không vậy ? mình kiếm hoài mà không thây có file tiếng việt . cảm ơn các bạ
được bạn aMXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0860086
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000C13A
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: nmwcdc, ver: 7.1.32.70
Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011)
Battery voltage: 3595 mV
Warning battery voltage is less, phone might not detected after flash !
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 5A25397
Device synchronized.
CPU: XGOLD 213
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.37
EBL version : Quantum_Bootloader_10.37_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 [Intel NU48F512,512 Mbits]
Processing file: rm692__06.51.mcusw
Downloading item CODE:rm692__06.51.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.438 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.422 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.531 s
Erasing area 0x40280000-0x41D3FFFE ...OK
Programming completed in 34.438 s
Checksum verified (0x7AA9)
Processing file: rm692__06.51.ppm_t
Downloading item CUSTackage_t.ppm_ebl_psi.fls, num block: 1, size: 5.18 MB
Erasing area 0x41DC0000-0x422EDACE ...OK
Programming completed in 7.500 s
Checksum verified (0xC330)
Processing file: rm692__06.51_001.image_t_globe_ph_9l1x4
Downloading item CUST:/Users/ccm65/ccm_wa/be1var/rm692 , num block: 1, size: 11.75 MB
Erasing area 0x424C0000-0x43E1FFFE ...OK
Programming completed in 18.125 s
Checksum verified (0x3AC7)
Total time for flashing process(boot+erase+write) was 7 min 16.281 s
Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: F28201C
Verifying communication to device OK.
Phone type: RM-692 (C2-02)
SW version: V 06.51 15-07-11 RM-692 (c) Nokia
Imei plain: 35864104276837-3
Product code: 059F138
Battery voltage: 3565 mV, current: 110 mA
Language Pack:
- not available.
Camera config: 06150123007025, ver:
Imei net: 35864104276837
Version: SIMLOCK SERVER
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 800000000003000B
có tv bạn hiền
navifirm load về múc thôi
rm692__06.51.ppm_t - 4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến
mình không đưa trực tiếp line được
có chia sẻ là ok rồi![]()
MỚI nạp 1 con nửa ok
lên navifirm tìm dòng " seap_t" tất cả đều có tiếng việt
CTY TNHH TM-DV SAIGON MOBILE
