    V.I.P Thanh_6868's Avatar
    Mặc định 5800 unlock ok by ATF mất 6 phút
    Khi login báo 20 phút nhưng ngồi hút chưa hết điếu thuốc có code, mất 25 credit
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    BootFlashModeDCT5Ex Succeeded after 3 Attempts
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 400C1921
    ID DWORD 4 : 01051103
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 18300009
    ID DWORD 1 : 8D960052
    ID DWORD 2 : E87F16AC
    ID DWORD 3 : DFB11677
    ID DWORD 4 : 96AC549D
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 47 9C 6D DE 39 42 E1 2C 42 9C 1D 6A DE D8 03 71
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum 13
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_2nd.fg
    Boot File - Version 011.034.00
    Boot File - Revision 0x0002 (2)
    eBB5ProtocolType == New
    PrepareBootstrapFile_DCT5 replaced "SILO" with "2ND\0"
    PrepareBootstrapFile_DCT5 replaced "BOOT_MEDIAX" with "BOOT_MEDIA0"
    Secondary Loader Sent...
    TransmissionTypeRequest_DCT5_NewProtocol
    TRANSMISSION_TYPE_REQUEST_BB5 GET_PROTOCOLS_BB5
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 3E 00 C0
    FPIF_TRANSMISSION_MODE_LIST_BB5 using default mode 04 DDRand2TX
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 02 41 02 04 00 36 03 00 00 61 1C
    Transmission Type Request Sent...
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> not detected
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0400 -> Flash
    Device ID : 0000 -> Type not in database
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> not used
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0040 -> KAT00F00RA
    Revision ID : 0121
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.5
    Checksum : 25
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files MuxOneNAND (03) ManID :00EC DevID :0040 ExtID :0000 RevID :0121
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    Size : 10000000 (256 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAPIDOv11_XSR15_alg.f g
    Algorithm File - Version 011.034.00
    Algorithm File - Revision 0x0002 (2)
    Algo Loader Sent...
    SendCodeStart_NewProtocol :
    SendCodeStart_NewProtocol_DCT5 : No Error - 0 (0x00)
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok...
    VPP Enabled by Software
    Using Internal VPP
    FLASH_VOLTAGE_INIT_BB5 : 5C 01 26 04 00 00 00 00 D4
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    76A20187051C30162EE91C77AE5E6011F5F1BA61
    Scanning Simlock Applet Type...
    OK
    PA_SL3 Applet detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    FlashInfo.RestartMode : 2
    Basic Phone Information
    MCU Version: V ICPR72_10w04.5 22-03-10 RM-356 (c) Nokia
    IMEI Plain : 352012042312545
    IMEI Spare : A352012042312540
    IMEI SV : 33520120423125460F
    Phone Model: Nokia 5800 XpressMusic
    Category : Classic Phone
    Phone Type : RM-356
    Extended Phone Information
    Product Serial Number: MDK996628
    Product Code : 0591831
    Module Code : 0204538
    Basic Production Code: 0592754
    Long Production SN : 0
    MCU SW Version : V ICPR72_10w04.5 22-03-10 RM-356 (c) Nokia
    HW Version : 1104
    RFIC Version : 17141716
    DSP Version : ICPR72_10w05
    Content Pack Version : v 50.2010.06.1_001_000_U01 17-03-10 vanilla RM356
    AHNE Version : 11
    APE SW Core Version : V 50.0.005
    Variant Version : V 50.0.005V 50.0.005 V 50.0.005
    APE Test Version : eno_version
    RETU Version : 16
    TAHVO Version : 22
    APE HW Version : 256
    APE ADSP SW Version : 256
    Wireless LAN ID : 0CD:EFD:B1:BA
    Bluetooth ID : 0CD:EFD:8A:AA
    CS Type : GSM850, GSM900, GSM1800, GSM1900, WCDMA I, WCDMA VIII
    Simlock Information
    CONFIG KEY : 8000000000000000
    PROVIDER KEY : 4500000088401881
    NETWORK NAME : KT;Korea (South)
    LOCK COUNTERS : KEYPRESS 1/3, FBUS 4/10
    SIMLOCK TABLE :
    Block [1] 1:Close
    SIMLOCK STATE : LOCKED
    SIMLOCK_TYPE : PA_SL3 (15-digit NCK)
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SECURITY_CODE : ENCRYPTED
    PHONE_MODE : TEST
    DCC ID : NOT USED
    Phone Type : RM-356
    HW Version : 1104
    AHNE Version : 11
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    SIMLOCK TABLE :
    Block [1] 1:Close
    PHONE_MODE : TEST
    BootFlashMode_DCT5
    TIME STARTS HERE
    1 SYSTEM_ASIC_ID 01
    2 EM_ASIC_ID 02
    3 EM_ASIC_ID 02
    4 PUBLIC_ID 12
    5 ASIC_MODE_ID 13
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    7 ROM_ID 15
    CRC 0 : 4B9B7510
    CRC 1 : 3E691FF8
    Checksum 13
    MessageID : 06
    SubBlocks : 06
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Index : 01
    Revision ID : 0000
    Block Length : 0B
    Device Index : 00
    Revision ID : 0121
    Block Length : 09
    Data : XSR 1.5
    Checksum : 25
    SendAlgoCode_DCT5..
    Flash Descriptor
    Device ID : 0040
    Revision ID : 0000
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    Algo Loader Sent...
    FUR control Ok...
    Using Internal VPP
    Pabub KEY Request
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    OK
    Dumping RSA Modulus...
    OK
    RSA Modulus OK
    Decrypt SL3 PM 120 HASHES for Brute Force Unlock
    Decrypting PM 120...
    PM 120 HASHES Extracted Successfully
    6AE7910103B65D8868B953425C26B2328687DDDB
    D6F01DB4D56B502A03DFD62C8B84DBD3D9DF9F9B
    EB2BCB48B2A209B9AD7A9CBD3362287D92675B99
    5B53F6FCA2792527ADC81903B444A3175B8CA9D3
    1753D64ED63F0A14676A29E609667E1DA0951A83
    A441EF3B2FA78B20843ED30BEC2E27A21E798D04
    D660AACC3933919E662F4BE207D7B761E63C4336
    4D49625C88FAC9D06255F90340BC4D8E2E9B08A9
    Log Files for Local Brute Force Saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042312545\352012042 312545.job
    C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042312545\352012042 312545.log
    C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042312545\352012042 312545.bcl
    C:\AdvanceBox Turbo Flasher\Nokia\Bruteforce\352012042312545\352012042 312545.sha
    Command Line for ighashgpu:
    Saved as MS Batch File: 352012042312545_ighashgpu.bat
    Command Line for oclHashcat-lite64 (AMD Cards 64-Bit OS):
    Saved as MS Batch File: 352012042312545_AMD_oclHashcat_64-bit.bat
    Command Line for oclHashcat-lite32 (AMD Cards 32-Bit OS):
    Saved as MS Batch File: 352012042312545_AMD_oclHashcat_32-bit.bat
    Command Line for cudaHashcat-lite64 (NVIDIA Cards 64-Bit OS):
    Saved as MS Batch File: 352012042312545_NVIDIA_cudaHashcat_64-bit.bat
    Command Line for cudaHashcat-lite32 (NVIDIA Cards 32-Bit OS):
    Saved as MS Batch File: 352012042312545_NVIDIA_cudaHashcat_32-bit.bat
    Process Done!
    Phone Type : RM-356
    HW Version : 1104
    AHNE Version : 11
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    SIMLOCK TABLE :
    Block [1] 1:Close
    PHONE_MODE : LOCAL
    DCC ID : NOT USED
    Calculated NCK Codes For 352012042312545
    Calculating Codes... Please Wait a while...
    Lock Type 15-digit NCK
    Level 1 [MNC+MCC ] #pw+787914253300868+1#
    Level 2 [GID1 ] #pw+749086430956469+2#
    Level 3 [GID2 ] #pw+420801985678871+3#
    Level 4 [MSIN ] #pw+680692270020172+4#
    Level 5 [MNC+MCC+GID1 ] #pw+811031444167876+5#
    Level 6 [MNC+MCC+GID1+GID2] #pw+442925936629334+6#
    Level 7 [ALL SIMLOCK(s) ] #pw+435248583321180+7#
    Click "Manual Send Unlock Code PSW" Button
    to send Unlock Codes to Phone via FBUS...
    If the phone does not accept Level 7 Codes,
    try using Level 1 Codes to unlock the Phone...
    Phone Type : RM-356
    HW Version : 1104
    AHNE Version : 11
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    SIMLOCK TABLE :
    Block [1] 1:Close
    PHONE_MODE : LOCAL
    Sending SP code: #pw+435248583321180+7#
    Sending FBUS Command
    FBUS Command Sent
    OK: code accepted
    Phone Type : RM-356
    HW Version : 1104
    AHNE Version : 11
    RETU Version : 16
    TAHVO Version : 22
    Simlock Information
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open
    SIMLOCK STATE : Not Locked
    PHONE_MODE : LOCAL
    Vì khách chấp nhận giá cao lên múc thôi chứ 25 credit cũng đắng quá
    ThanhlongmobileServieCenter
    Số 2 An kim Hải-Lê Chân-Hải Phòng:ĐT: 0942006868, yahoo: Thanhkienan@yahoo.com
  2. ( Thanh_6868 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ThanhHai_GSM (23-12-2011)
  1. I 5800 unlock ok by LGtool
    By phung77 in forum QUALCOMM Models (3G)
    Bài viết cuối: 11-11-2013, 15:59
  2. HOT Nhận Unlock tất cả Nokia BB5 SL3 trong vòng 15 phút to 30 phút
    By Hoang Thong Mobile in forum Dịch vụ unlock trực tiếp điện thoại di động
    Trả lời: 34
    Bài viết cuối: 18-07-2012, 08:26
  3. HOT Nhận active Mxkey unlock SL3 trong vòng 1 phút giá 670.000 VND
    By saigonmobile in forum GIỚI THIỆU THIẾT BỊ - CABLE - GIẢI PHÁP MỚI NHẤT
    Trả lời: 36
    Bài viết cuối: 04-03-2011, 08:56
  4. 5800 unlock cần giúp
    By Ghost_Mobile™ in forum BB5
    Bài viết cuối: 01-03-2011, 17:30
  5. Trả lời: 1
    Bài viết cuối: 29-11-2008, 02:18
