Kết quả 1 tới 10 của 11
    Feb 2011
    thanh hóa
    Mặc định 110i nạp pm ko nhận xin giúp
    mình nhận kây 110i < lên xong chớp tắt >
    bở vào jaf + mxbox chạy báo lổi .xóa rồi nạp ko vào nổi
    đả thay giao động + thạch anh
    máy đang còn nguyên full chưa ai đụng vào
    log chạy đây nhờ anh em xem qua < gấp quá ,nhờ anh em giúp tay thank trước nha >
    Getting MCU ID
    MCU ID: 0x2201
    FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    First 16 bytes: 8F AE 64 5F F7 B7 E1 B9 7D AE 60 DF F7 B7 E1 BD
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Filipino,Vietnamase
    PPM Flash file: NONE
    CNT Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Phone Type:
    Phone Type:
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.020
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: 8F AE 64 5F E7 B7 E1 B9 7D AE 64 DF F7 B7 E1 BD
    Flash ID is 0x72888900
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u_intel.fia
    Loader size is 0x5538; Loader chk: bb
    Loader is ready...
    MSID: 84FC0E646A38013C035C69E916
    MSID decoded: 3E4EBAE900129F6AAA000000
    FAID: 950B9D6E16EFAD4337C23FD9
    Erasing...
    Found 5 interval(s) to erase
    Erasing area: 01010000 - 013BFFFF...
    Erasing area: 013C0000 - 013EFFFF...
    Operation took 0 minutes 38 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 15 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh93_07.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: 8F AE 64 5F E7 B7 E1 B9 7D AE 64 DF F7 F7 E1 BD
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 011E0000 - 011EFFFF...
    Erasing area: 011F0000 - 0137FFFF...
    Operation took 0 minutes 16 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\RH-93\rh930_nai7.02md
    Booting phone...
    MCU ID: 0x2201
    Boot size is 0x09A0
    Boot is ready...
    First 16 bytes: 8F AE 64 5F E7 B7 E1 B9 7D AE 60 5F F7 B7 E1 BD
    Loader is ready...
    MSID: 847ABDEEB2C904F93B81E29F9F
    MSID decoded: 3E4EBAE900129F6AA8000000
    FAID: EC26B959BE796551F56229E5
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 01380000 - 013BFFFF...
    Operation took 0 minutes 2 seconds...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 11 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    call :0976 001 628
    Feb 2011
    thanh hóa
    up phát cho sự chờ đợi
    có lẻ phải chiến upp và flatsh vậy .anh em cho ý kiến nào
    call :0976 001 628
    Moderator Dong_Mobile's Avatar
    Nov 2010
    che chân VPP lại Flast tiếp xem thế nào,không đc múc UPP
  4. ( Dong_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanhung.dd (26-12-2011)
    Feb 2011
    thanh hóa
    đả che rồi not ok có cao kiến j thêm ko các bạn ?
    call :0976 001 628
    Thành viên chính thức vthanh83's Avatar
    Oct 2010
    Ho Chi Minh
    bạn thay cáp chạy khác xem sao rồi tính tiếp
  7. ( vthanh83 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  8. #6
    Feb 2011
    thanh hóa
    thay rồi bạn nhé nhửng vấn đề nhỏ đả làm hết
    call :0976 001 628
  9. #7
    Moderator Phạm Nguyên's Avatar
    Nov 2011
    Đất_ Mẹ_ Anh _Hùng
    vậy thì upp thẳng tiến
  10. ( Phạm Nguyên ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    tuanhung.dd (27-12-2011)
  11. #8
    Moderator Apple179's Avatar
    Sep 2010
    Trích Được post bởi tuanhung.dd Xem bài viết
    vậy còn chò đọi gì nũa bạn....múc thảng cpu..lẹ lên kiếm lúa còn đi chỏ tết........
    DV sửa chữa iphone cho anh em
  12. ( Apple179 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #9
    Feb 2011
    thanh hóa
    ok chiến cái rồi báo cáo anh em sau
    call :0976 001 628
  14. #10
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    xem còn con trở đôi BSI ko?
  1. điện thoại 110i không gủi được tin nhắn
    By vanlidochanhxg in forum DCT4 - WD2
    Trả lời: 21
    Bài viết cuối: 27-04-2011, 19:32
  2. 110i cần giúp đỡ
    By mobile_longngu in forum DCT4 - WD2
    Bài viết cuối: 01-04-2011, 08:40
  3. nokia 110i không nhận sim
    By vanngocmobile in forum DCT4 - WD2
    Bài viết cuối: 14-10-2010, 21:37
  4. xin fine tải nhạc chuông cho 110i.1200.6030
    Bài viết cuối: 14-06-2010, 23:21
  5. MMB cài nhạc đươc 110i , không cài được 1200 help me..
    By mankichi in forum Chuông cho điện thoại di động
    Trả lời: 14
    Bài viết cuối: 10-01-2009, 16:39
