cây c3-00 bị mã bảo vệ mình lấy mxbox reset cho nhanh ,nhưng vào được chế độ TESTMODE nhưng ko reset đc nó báo lỗi ,đây là log của nó
XKEY [MxKey Team HTI Flasher Interface (WinUSB) 5], SN: C0859233
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.70
Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1CDD1123
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 00000000001C0CDEAE59815E2BF8D3D26E90C4DF
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
CMT PAPUBKEYS HASH: 697F747788AD72E77DB3BC8DFEC0C28DA22F16D8
Original Imei: 35376004627850
Original Product code: 0594046
Bluetooth ID: D4CBAFEEA713
SIMLOCK PA identifier:
[0] PA_SL3
Reading CMT NPC (0x190 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Device connected: nmwcdc\Nokia C3-00 USB Phonet, PORT_ID: 322AC911
Verifying communication to device...
ERROR: Could not verify communication !
Market items is empty, please select the correct products path !
mong anh em cho minh ý kiến thank !!!!!!!!!!
			 c3-00 mã bảo vệ
 c3-00 mã bảo vệ
