    Thành viên chính thức phungvannghiempc's Avatar
    Thumbs down xin hướng dẫn mua log N81 8G
    tình hình em mới nhận con N81 của khách đã qua thợ khác làm mở nguồn hiện nokia rồi treo em cho vào mx check thì log như sau
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08569CD
    Using device: HTI, FW ver: 00.24, SN: 0001306F
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 10B000125A860058B5062B37614E933C37A3AA4B
    ASIC MODE ID: 00
    ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
    ROM ID: A8C1D6713E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
    CMT PAPUBKEYS HASH: E70C21157D5AB5AF61AAD376910751FB06D6E9FD
    Original Imei: Empty
    Original Product code: Empty
    NPC_DATA invalid !
    SIMLOCK PA identifier:
    [0] PA_SL2
    Phone type: RM-179 (Nokia N81)
    SW version: V 06wk41v62.4 04-12-08 RM-179 (c) Nokia
    Imei plain: 12345610654321-?
    Product code: 0545902
    Battery voltage: 4709 mV, current: 7 mA
    ApeCoreSw: 21.0.010
    ApeVariant: 21.0.01021.0.010_14.01
    ApeTest: rm179_ENO_x_2007wk24v0.070
    Language Pack:
    - not available.
    SLPA ver[2]: PA_SL2 (15 digit NCK)
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei plain is invalid !!!
    Imei net: 12345610654321?
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    em nhìn thấy cái imei đẹp quá bây giờ là phải mua rpl rùi nhưng em không biết mua thế nào em có mxkey thui mong các bác giúp đỡ
    khi ta ở đất chỉ là đất ở
    khi ta đi đất bỗng hoá linh hồn
    Moderator TÚ CÒI's Avatar
    hà nội
    Nếu còn rpl thì nạp lại
    ko có thì thay cặp thôi nhé
    ko có giải pháp gửi file như DCT4
    V.I.P ĐƠ_NGUYỄN's Avatar
    chắc phải thay cập thôi
  4. ( ĐƠ_NGUYỄN ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (01-01-2012)
    ok để em báo khách
    Feb 2011
    thanh hóa
    Trích Được post bởi phungvannghiempc Xem bài viết
    ok để em báo khách
    báo nửa máy là ok đó
    call :0976 001 628
    Oct 2010
    thay căp thôi ban ơi
    Oct 2010
    liên hê mình còn 1 men n81 full dc mình chia lai cho 0984813138
  9. #8
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Nếu lúc đầu có backup thì restore imei lại không thì thay cặp thôi.
