    Thành viên chính thức s.y_mobile's Avatar
    Jul 2011
    Mặc định Plash E71 báo lỗi xin giúp
    Em nhận kêy E71 nó vẫn bình thường nhưng giao diện như máy TQ vậy
    em kiểm tra thì đúng là máy công ty và check + Scan đều ok
    em Plash bằng JAF và Mx box đều không được
    đây là log mx box ae xem giúp ạ
    Version from phone: 510.21.009
    Version from file: 510.21.009
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085BEBA
    Using device: HTI, FW ver: 00.24, SN: 0001099F
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35485604654385_BA CK.rpl).
    CMT Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 2250011760A90052CCB92E1B19B1EC8FD2AC10F8
    ASIC MODE ID: 00
    ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
    ROM ID: 4B9B75103E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
    Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30
    CMT PAPUBKEYS HASH: 52570A2086C79E6965175815B5388535CDD5C6F7
    Processing MCU file: rm346_510.21.009_prd.c00
    [BB5,XSR 1.5] size: 67.83 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning ...OK
    Erase size: 122.56 MB
    CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
    CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
    Formating partition ...
    Prog.status for Asic CMT ...
    NAND: OK
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 52570A20 [RAP Certificate 101 v1] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS*CORE block sent
    CMT SOS+ROFS block sent
    NAND: OK
    Programming completed in 3 min 13.984 s
    Processing PPM file: rm346_510.21.009_prd.v29
    [BB5,XSR 1.5] size: 22.51 MB
    Erase size: 33.56 MB
    CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
    NAND: OK
    CMT SOS+ROFX block sent
    NAND: OK
    Programming completed in 1 min 6.468 s
    Processing CNT file: RM346_ENO_0741.10_08wk42.a36.fpsx
    [BB5,XSR 1.5] size: 1.53 MB
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 400C192101031103, 4003192101031103, 4003192101051103, 400C192101051103
    Converting UCP blocks to 128 K.
    Error converting UCP!
    Processing CNT file: leevi_erase_y_drive.fpsx_128
    [BB5,XSR 1.5] size: 244 Bytes
    Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 400C192101031105
    Erase size: 1.62 MB
    CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF]
    NAND: OK
    Programming completed in 0.015 s
    Processing CNT file: rm346_510.21.009.01U
    [BB5,XSR 1.5] size: 18.05 MB
    Total time for flashing process(boot+erase+write) was 4 min 30.406 s
    Phone type: RM-346 (Nokia E71)
    SW version: V ICPR71_09w47.10 20-01-11 RM-346 (c) Nokia
    Imei plain: 35485604654385-3
    Product code: 0561926
    Battery voltage: 4752 mV, current: 55 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 354856046543853
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Moderator TÚ CÒI's Avatar
    hà nội
    Log này ok mà
    Lỗi gì bạn
    Nếu cái phông vẫn lỗi thì bạn load file khác,code khác là ok mà
    Jul 2011
    Báo lỗi dòng chữ đỏ đó anh
    và chạy xong khi bật lên vẫn như cũ
    hà nội
    Trích Được post bởi s.y_mobile Xem bài viết
    Lấy USB dùng phoenix chạy coi sao a
    chuyển qua box khác fash lại mx chuối lắm nhiu khi no hay bi vậy jaf chiến tốt e này
  1. c3_01 plash đơ phím và cảm ứng xin giúp
    By haanmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 14-07-2013, 16:21
  2. Trả lời: 8
    Bài viết cuối: 30-01-2013, 20:59
  3. xin giúp 6233 plash báo failed
    By manhhung202000 in forum BB5
    Bài viết cuối: 13-01-2012, 22:40
  4. giúp plash w595
    By TLT_mobile in forum Các loại models mới Sony-Ericsson
    Bài viết cuối: 28-10-2009, 12:38
  5. Cần giúp file 6120 cpu6226 plash spansion 16m
    By pnkhiem in forum Phần mềm và các mã lệnh
    Bài viết cuối: 12-10-2009, 13:57
