Kết quả 1 tới 10 của 11
    Thành viên mới manhvietnam87's Avatar
    May 2011
    Mặc định 5228 báo phone start up failed contact the retailer
    em mới nhận chú 5228 khởi động vẫn hiện nokia rồi chớp tát vài nhát rồi máy báo
    phone start up failed contact the retailer cho vào jaf thì k chk vs inf được e chạy bằng mxkey thì ok hét k báo lỗi j mà bật lên vẫn vậy các bác đã làm wua xin chỉ giúp em voeis a e chạy v51.1.002
    Moderator TÚ CÒI's Avatar
    hà nội
    check rồi quăng cái log coi nào bạn
    TP Hồ Chí Minh
    cho vào N-box format = done
    May 2011
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 330479E0
    CMT SYSTEM ASIC ID: 000000010000022600010006
    400C192101051105 [RAPIDOYAWE ver: 1.1x]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0E40010B69A3005232611A0D2F1FC7E5A6942F02
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH:
    B8C3ADECFC997FCD8081D3DEAF870B8C
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    CERT backup skipped.
    CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 158.19 MB
    CMT FLASH,MuxOneNAND area [00040000-00082FFF]
    CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
    CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
    CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
    CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent
    CMT SOS*UPDAPP block sent
    CMT SOS*ENO block sent
    CMT SOS*DSP0 block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 1 min 31.921 s
    Processing PPM file: RM-625_51.1.002_prd.rofs2.V05
    [BB5,XSR 1.6] size: 26.01 MB
    Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
    Erase size: 36.50 MB
    CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 25.562 s
    Processing CNT file: RM625_51.1.002_000_001_U001.uda.fpsx
    [BB5,XSR 1.6] size: 17.07 MB
    Erase size: 86.12 MB
    CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF]
    Programming completed in 18.078 s
    Total time for flashing process(boot+erase+write) was 2 min 22.672 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia 5800 XpressMusic USB Phonet, PORT_ID: 370DCE50
    Verifying communication to device OK.
    Phone type: RM-625 (Nokia 5228)
    SW version: V ICPR72_11w16.1 28-07-11 RM-625 (c) Nokia
    Imei plain: 35271504992066-0
    Product code: 059B917
    Battery voltage: 3819 mV, current: 295 mA
    ApeCoreSw:
    V 51.1.002
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 352715049920660
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    May 2011
    băng mxkey đó bác a jaf k chay được
    V.I.P phungtien's Avatar
    cà mau
    fomat cái coi sao bạn
    SÓNG GIÓ CUỘC ĐỜI NUÔI TA LỚN,BÃO TÁP CUỘC ĐỜI DẠY TA KHÔN
    May 2011
    fomat rồi bác ạ
    liệu co phải động tới phần cứng k các pro nhỉ
    May 2011
    mọi người đâu hết rồi k ai giúp e hết sao ?
    ai đã làm wua xin giúp e với a cám ơn nhiều
    Chú ý : Bạn post theo kiểu vừa rồi là bị banned đó nha ! ( nnm )
    V.I.P Thanh_6868's Avatar
    SIMLOCK_TEST passed
    Counter: 0/3, 0/10
    Log đẹp ,múc con ic nguồn trước xem thế nào
    ThanhlongmobileServieCenter
    Số 2 An kim Hải-Lê Chân-Hải Phòng:ĐT: 0942006868, yahoo: Thanhkienan@yahoo.com
    TP Hồ Chí Minh
    cái này thường là fotmat fulfactory là done
  1. Trả lời: 12
    Bài viết cuối: 11-11-2012, 17:51
  2. N70 Phone Start-up Failed ! Contact the retailer
    By tridai_mobile in forum BB5
    Bài viết cuối: 25-02-2011, 08:27
  3. Trả lời: 15
    Bài viết cuối: 14-01-2010, 10:45
  4. Trả lời: 9
    Bài viết cuối: 05-06-2009, 09:37
  5. Trả lời: 10
    Bài viết cuối: 18-11-2007, 20:01
