Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 21
    Thành viên chính thức suwaree's Avatar
    Mặc định <<BB5 Easy Tool by DSSv03 new update>>
    BB5 EasyTool v0.3 aka DSS
    Supported interface:
    USB, COMport, UFS
    How to Read an ASK files from BB5 phones:
    - Switch ON the phone
    - Install the phone using Supported interface.
    - Open DSS.exe
    - Select phone 'connection' then Click 'Connect'
    - Click 'Read ASK'
    How to Write RPL files to BB5 phones:
    - Open DSS.exe
    - Click 'Write RPL'
    - Note: This function will write only SIMLOCK DATA to the phone, for imei repair you need flashers!
    How to use DSS as easyUID:
    - Copy DSS.exe to UID directory
    - Make proper testpoint to the phones
    - Switch ON the phone(with CORRECT testpoint connected between phone and UID BOX)
    - Open DSS.exe
    - For better result, you should set then phone mode to 'TEST MODE' before unlock process
    - You will see 'easyUID' page.
    - Click 'Hook'
    - Select Phone model listed on bb5_unlock.exe(UID SW)
    - Click 'Init' on bb5_unlock.exe
    - Set 'options' to use #pw+...+?# if required.
    - Click 'SP unlock' ('delay' before unlock process implemented)
    - Wait for bb5_unlock.exe to work, DSS.exe will automaticaly detect the code calculated by bb5_unlock.exe and write it to the phone.
    http://www.gsmsimlocking.com/BB5/ind...asy+UID+by+DSS
  2. ( suwaree ) đã được 25 thành viên cám ơn vì bài viết hữu ích!
    dodungstc (27-11-2007), dtd1215 (21-11-2007), hoanghungmobile_gl (21-11-2007), hoangnam1980 (22-11-2007), htv1810 (26-11-2007), hungpdahl (21-11-2007), HuuLanh (26-11-2007), HuyenNam (23-04-2009), iniks_bg (25-11-2007), J-mobi (19-11-2007), nd mobile (19-11-2007), ngaymaitroilaisang (21-11-2007), nguyenminhkhoa (09-04-2008), nhacmp3 (27-11-2007), phucloc_mobil (22-11-2007), P_Mobile (26-11-2007), qnh (17-10-2009), quang12000 (26-11-2007), sybenlove (25-11-2007), tcc (19-11-2007), trantam1 (19-11-2007), tuanwawezx (21-11-2007), ut_123 (22-11-2007), why not bar (24-11-2007), ymobile (02-12-2007)
    Thành viên chính thức HHHHHH's Avatar
    Dec 2006
    thanks very much
    Thành viên chính thức nd mobile's Avatar
    Jun 2007
    thanks rồi sao kô thấy hiển thị phai dow nè
    Thành viên tích cực thevinh2988977's Avatar
    Nov 2006
    chùa TÒA THÁNH
    thanks rùi mà ko thấy thì nhấn F5 NHA ANH !
    Bác sĩ mobile suốt đêm dài không ngủ
    Thức trắng đêm hoài sao chẳng đủ tiền chi
    Thành viên mới 23061983's Avatar
    Mar 2007
    cám ơn nhiều nha
    V.I.P Tamansu's Avatar
    Feb 2006
    www.*******.vn
    thank share
    DƠNLOAD 4500 GAME BẢN QUYỀN APPLE
    Yahoo! DT: 01234.0123.02 - tamansu
    Thành viên chính thức dtd1215's Avatar
    Nov 2005
    Thank + F5 vẩn ko thấy , post 1 phát thì thấy ngay
  9. #8
    Thành viên chính thức ngaymaitroilaisang's Avatar
    Apr 2007
    Thank rồi cũ ko thấy gì?
    Chuyên mua bán box,thiết bị cũ!
    Repair all mobile. ĐT:0988976269!
  10. #9
    Thành viên chính thức hungpdahl's Avatar
    Apr 2006
    Cám ơn bạn đã chia xẻ cùng anh em.
  11. #10
    Thành viên chính thức hoangnam1980's Avatar
    Apr 2007
    hay quá thanks nhiều
  1. BB5 Easy Service Tool (BEST) Nokia Dongle new update
    By TUYHOAGSM™ in forum Infinity Box
    Bài viết cuối: 09-06-2015, 14:08
  2. Volcano Tool (Utility) v2.7.2 Exclusive Update With Easy GUI & Improved Performance
    Bài viết cuối: 29-06-2014, 09:48
  3. Easy-Jtag & Emmc TooL 1.0.53.0 Update. Galaxy Note 2 boot repair, SHV-E120S repair
    Bài viết cuối: 23-07-2013, 09:32
  4. Easy-JTAG Update. 1.0.50.0 Update. EMMC tool improved. GPS navigators support added.
    Bài viết cuối: 15-07-2013, 19:11
  5. REAL EMMC TOOL Released. No any fake. :) EASY-JTAG Update 1.48.0
    Bài viết cuối: 05-07-2013, 10:12
