Kết quả 1 tới 10 của 18
    Thành viên tích cực ko.ko80's Avatar
    Jul 2011
    Mặc định 3110c flash lỗi mong ae giúp
    ae xem hộ cái llog dùm mình với
    ATF Software Version v8.00
    ATF Lightning FBUS Flash Started...
    Number of Image Files: 3
    Processing Image File :
    D:\FILE FLASH\NOKIA\BB5\3110c_RM-237_v7.21\RM-237\rm237__07.21.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000 Hz
    Algorithm Sending Speed : 6500000 Hz
    Program Sending Speed : 6500000 Hz
    Message Reading Speed : 98000 Hz
    Number of Blocks : 944
    Entry Point : 0x44FC
    Page Format : 128K
    Maximum Page Size : 0x00004000
    Changing MODE : FLASH
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 010C1921
    ID DWORD 4 : 01001101
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000232
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000353
    4 PUBLIC_ID 12
    ID DWORD 0 : 25E00009
    ID DWORD 1 : 17EE7E56
    ID DWORD 2 : A6DA335D
    ID DWORD 3 : 4EE4A0E0
    ID DWORD 4 : 1325C182
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : BA F3 A9 C3 DB FA 84 54 93 7D B7 7F 2B 88 52 B1
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 191EC665
    CRC 1 : DFAAF68F
    Checksum EB
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8981 -> NU48F256
    Extended/Fixed ID : 0000
    Revision ID : 6A21
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 82
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8981 ExtID :0000 RevID :6A21
    Flash Descriptor
    Device ID : 8981
    Revision ID : 0000
    Size : 02000000 (32 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    C0E691EA16A7593A9BB28832D7312A39F7ED668D
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 03 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 A2
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x4E (78)
    ERASE Blocks : 0x01 (1)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x4B (75)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00000000-000006BF
    1 : 000006C0-0001FFFF
    2 : 00020000-0007FFFF
    3 : 00080000-000DFFFF
    4 : 00100000-001FFFFF
    5 : 00200000-0031FFFF
    6 : 00320000-0105FFFF
    7 : 01060000-01067FFF
    8 : 01068000-0107FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    Block Length : 01
    BB ASIC Index : 00
    Successfully erased..
    Time Taken to Erase : 00:01:37
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    ReturnedType : 04 DDR & 2TX
    Flashing Speed: 5.00 Mhz
    Processing : rm237__07.21.mcusw
    Total blocks to write : 944
    FBUS Cable RX2 PIN Diagnostics
    Block Length : 01
    BB ASIC Index : 00
    INFO: RX2 PIN is OK
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : PMM_CONF
    >> CMT Rootkey Hash CERT : SBIF_CONF
    ContinueFlash_DCT5 Complete
    Block Length : 01
    BB ASIC Index : 00
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:00:50
    D:\FILE FLASH\NOKIA\BB5\3110c_RM-237_v7.21\RM-237\rm237__07.21.ppm_v
    CMT Type : BB5
    Number of Blocks : 279
    Entry Point : 0x00A6
    Page Format : 128K
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01080000-0151FFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:29
    Processing : rm237__07.21.ppm_v
    Total blocks to write : 279
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:11
    D:\FILE FLASH\NOKIA\BB5\3110c_RM-237_v7.21\RM-237\rm237__07.21.image_v
    CMT Type : BB5
    Number of Blocks : 320
    Entry Point : 0x00B2
    Page Format : 128K
    Using Internal VPP
    StartErase_DCT5...
    Device Index : 0x00
    0 : 01520000-01FDFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:01:24
    Processing : rm237__07.21.image_v
    Total blocks to write : 320
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:12
    Total Flash Write Time (Flashing Only) : 00:01:13
    Total Flashing Time (Booting + Erase + Flashing) : 00:04:44
    FlashInfo.RestartMode : 2
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Basic Phone Information
    ko đồng bộ được ae ơi
    tình trang ban đầu máy thế nào mà bị như thế cho ít thông tin đi bạn
  3. ( Trường_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ko.ko80 (13-01-2012)
    Jul 2011
    nó mở nguồn lên nokia rùi tắt
    mà nge khách nói là đan nge nhạc tự nhiên nó bị zax a
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    lên ver 7.30 rồi flash lại anh
  6. ( VŨ PRO ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Jul 2011
    có file 7.30 tiếng việt ko cho mình xin flash phát nữa xem sao thanks
  8. #6
    flash 7.30 cho len nguồn sau đó lấy file ppm 7.21(tv) flash vô
  9. ( QUỐC MẠNH ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    conggsm (13-01-2012), ko.ko80 (13-01-2012)
  10. #7
    Jul 2011
    Trích Được post bởi QUỐC MẠNH Xem bài viết
    làm zax có ổn ko bác
  11. #8
    Thành viên tích cực chanhtl's Avatar
    Jun 2011
    ĐỨC HÒA LONG AN
    Trích Được post bởi ko.ko80 Xem bài viết
    rất ổn nửa là
    cách chọn file ppm 7.21 là ok nhất
    đã lụm lúa rất nhiều
    cứ mạnh dạng mà phan nó đi you ah
  12. ( chanhtl ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
  13. #9
    Jul 2011
    Trích Được post bởi chanhtl Xem bài viết
    rất ổn nửa là
    mình phan vào nó trắng màn hình rùi you ơi
  14. #10
    chay 7.3 repe luôn chay pm full_>ko hết đóng ic nguồn lớn vừa gặp 1 chu hôm wa
  15. ( hachanyen ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. Trả lời: 16
    Bài viết cuối: 13-05-2012, 11:49
  2. 3110c bệnh lạ mong anh em giúp đỡ thank.
    By nguyenlaluong in forum BB5
    Bài viết cuối: 10-04-2012, 08:06
  3. 3110c mong được chỉ giúp
    By Taichimlon in forum BB5
    Bài viết cuối: 20-03-2010, 19:15
  4. 3110c mong đc giúp đỡ
    By trieuthihang in forum BB5
    Bài viết cuối: 29-08-2009, 09:18
  5. 3110c rất mong đươc trợ giúp
    By Cuong_NT in forum BB5
    Bài viết cuối: 15-09-2008, 16:57
