Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 22
    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định 1280 rớt đất mất nguồn xin giúp!
    1280 rớt đất mất nguồn, Đã thay màng hình khác , máy còn dao động,
    bắm nút nguồn thì kim dòng nhịp điều ở 0 mà máy ko lên nguồn ,
    còn đây là log check , xin ae chỉ giáo thêm
    thanks all
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Dec 2011
    còn đây la log flash lại em nó, xin ae giúp đỡ
    Do not disconnect or abort this operation otherwise phone will be damaged.
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    Processing file: rm647_006.510
    Downloading item CODE:hw_b2_rm647_r06.510.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 37.969 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 36.484 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.171 s
    Checksum mismatch: Phone calculated 0x3171, software calculated 0x72AB
    Processing file: rm647_006.51mr
    Downloading item CUST:hw_b2_rm647_006.51mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 21.344 s
    Checksum mismatch: Phone calculated 0xE960, software calculated 0x1507
    Processing file: rm6470_nai06.51mr
    Downloading item CUST:hw_b2_rm6470_nai06.51mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 5.688 s
    Checksum mismatch: Phone calculated 0x050C, software calculated 0xA1D0
    Total time for flashing process(boot+erase+write) was 2 min 58.797 s
    Thành viên mới minh_hungmobile's Avatar
    Oct 2009
    coi lại đường màn hình đi có bị rỉ đức đường kg mấy loại nầy thường bị đức đường do rớt nước
  4. ( minh_hungmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (26-01-2012)
    Moderator TÚ CÒI's Avatar
    hà nội
    đo lại chân màn là ok tới 95%
  6. ( TÚ CÒI ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (26-01-2012)
    Thành viên tích cực gsmmientrung's Avatar
    Jan 2012
    anh thử info xem có dc ko nếu mà info ok thì anh xem lại dương màng hình,, còn hong info đươc thì làm do máy mất nguồn rồi
  8. ( gsmmientrung ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (26-01-2012)
  9. #6
    Dec 2011
    info ko được anh ơi, để em check lại đường màng hính
  10. #7
    V.I.P Hoat_Hai's Avatar
    Jan 2008
    Đo lại đường màn thật kỹ, nơi tiếp xúc màn với mên, nhất là cuộn dây và con tụ ngoài cùng bên phải phía trên khu vực led đó bạn
    Các bạn là thầy của tôi
  11. ( Hoat_Hai ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (26-01-2012)
  12. #8
    Jan 2012
    không infio dc thì máy ko có nguồn anh á, đúc đường màng hình thì máy vẩn info ok,, anh xem kỷ lại khu vuc CPU xem có hở ko, khò nhẹ CPU và con Lash xem sao anh á
  13. #9
    Super Moderator namnhatrang's Avatar
    Jan 2007
    thay màn là oki , nếu có atf scan phát biết ngay , chyên gia hư lcd
  14. #10
    Jan 2012
    nói chung cái này thì trước lúc làm đo xem chan LCD tên main có trở đầy đủ ko..rồi tes thừ cái màng hình ... mà cái này ko info dc thì 99% là ko phải màng hình ,, lưu ý : nếu máy có nguồn bình thường.. có duc đường LCD hay hư LCD đi nữa vẩn info bình thương á
  15. ( gsmmientrung ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    ngoc151na (23-02-2012)
  1. Trả lời: 1
    Bài viết cuối: 12-02-2014, 21:22
  2. Trả lời: 11
    Bài viết cuối: 11-02-2014, 15:37
  3. 1280 mất nguồn cần giúp !!!
    By newnice in forum DCT4 - WD2
    Bài viết cuối: 04-06-2012, 15:31
  4. 1280 rớt nước mất nguồn xin giúp!
    By chienkute654 in forum DCT4 - WD2
    Bài viết cuối: 12-05-2012, 17:33
  5. xin xem giúp log 1280 mất nguồn
    By ĐƠ_NGUYỄN in forum DCT4 - WD2
    Bài viết cuối: 01-11-2011, 15:41
