Kết quả 1 tới 10 của 15
    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định 2700 flash bằng phonix ở chế độ dead phone xin giúp
    2700 máy đang sử dụng mất nguồn, bâm nguồn kim dòng treo o,1a. em check không ra hết nên ko backup được, chạy bằng phonix thì báo lổi thế này , xin ae giup
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Scanning image files...
    Waiting for USB device...
    1. Make sure USB cable, Battery and charger are removed from device.
    2. Insert USB cable to device
    3. Insert Battery to device
    4. Insert Charger to device
    --- Press phone's power button! ---
    Loading secondary boot code: 14592 bytes
    Secondary boot loaded
    Loading update server code: 308032 bytes
    Update server loaded
    Starting to recover the phone
    Recoverying phone
    Initializing
    Error initializing Algorithm. 0x84009427
    ERROR: Failed to set phone to flashmode
    Unable to set the phone to flash mode. Unable to flash.
    Flashing phone
    Initializing
    Recoverying phone
    Initializing
    ERROR: Unable to detect device 0x8401F145. Check USB connection!
    Flashing phone
    Initializing
    Recoverying phone
    Initializing
    All operations completed
    Product flashing aborted
    Dec 2011
    còn đây là log check bằng mxbox
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    PUBLIC ID: 0F700102F1F101560F979191BB4BC8F96E4FF761
    ASIC MODE ID: 00
    ROM ID: 273F6D55DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2400 - 0000 8A31 [Samsung ] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Original Imei: 35431304117493
    Original Product code: 0579808
    Bluetooth ID: 303855260800
    Nov 2010
    làm phần cứng đi bạn ơi
    máy chưa có buscheck được mà
  4. ( toilatoi142001 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (05-02-2012)
    Moderator TÚ CÒI's Avatar
    hà nội
    chạy bằng box đi nhé
  6. ( TÚ CÒI ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    99999 (05-02-2012), daochikien (30-03-2012)
    Dec 2011
    em đã flash 3 lần cùng 1 kết quả như thế này
    xin ae chi giáo.
    thanks ae
    CMT Data :
    EM0 ID: 00000296
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    Processing MCU file: rm561__09.98.mcusw
    [BB5,BB5 ALGORITHM] size: 19.41 MB
    Erase size: 21 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00040000-000BFFFF]
    CMT FLASH,NOR area [000C0000-0013FFFF]
    CMT FLASH,NOR area [00140000-0137FFFF]
    CMT FLASH,NOR area [01380000-0151FFFF]
    erased in 1 min 19.937 s
    Prog.status for Asic CMT ...
    NOR: OK
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
    CMT UPDAPP block sent
    CMT DSP0 block sent
    CMT MCUSW block sent
    NOR: OK
    Programming completed in 1 min 12.046 s
    Processing PPM file: rm561__09.98.ppm_t
    [BB5,BB5 ALGORITHM] size: 6.62 MB
    Erase size: 8.62 MB
    CMT FLASH,NOR area [01520000-01DBFFFF]
    erased in 28.547 s
    NOR: OK
    NOR: OK
    Programming completed in 24.954 s
    Processing CNT file: rm561__09.98.image_ctv_au_black
    [BB5,BB5 ALGORITHM] page size: 128 K size: 10.89 MB
    Erase size: 34 MB
    CMT FLASH,NOR area [01DC0000-0215FFFF]
    CMT FLASH,NOR area [02160000-03FBFFFF]
    erased in 1 min 5.734 s
    NOR: OK
    NOR: OK
    Programming completed in 41.282 s
    Total time for flashing process(boot+erase+write) was 5 min 19.718 s
  8. #6
    Dec 2011
    còn đây là log flash bằng usb, xin ae chỉ giáo giúp
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000B3E9
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.73
    Waiting for USB ROM device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3AE7296B
    CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0F700102F1F101560F979191BB4BC8F96E4FF761
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
    CMT ROM ID: 273F6D55DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x3900 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Failed to set phone to flashmode, possible reason: Update Agent not running or PASUBTOC corrupted !
    Please recover phone using FBUS.
  9. #7
    Dec 2011
    up lên cho ea giúp
  10. #8
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Trước tiên bạn backup RPL lại.(Nếu backup = MX thì chọn APE vì máy đang dead,hoặc dùng hộp JAF...)
    Sau đó lấy Ver cao nhất của 5130 flash cho nó xem có tỉnh ko?(Mục đích là để backup đc PM full )
  11. #9
    May 2011
    Hà Nội City
    Tình trạng máy lúc đầu thế nào bạn?
    khả năng lớn là lỗi cặp rùi
    dòng này lôic cặp rất nhiều
  12. ( ĐẶNG BẢO_GSM™ ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
  13. #10
    PHÚ ĐIỀN-TÂN PHÚ-ĐỒNG NAI
    cái này lỗi phần cứng rồi anh ,múc 2 con nguồn nhỏ trước rùi tính tiếp
  14. ( nhathuy_mobile2009 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (05-02-2012)
  1. Trả lời: 15
    Bài viết cuối: 16-09-2013, 18:29
  2. Trả lời: 21
    Bài viết cuối: 23-12-2012, 19:09
  3. Trả lời: 9
    Bài viết cuối: 15-04-2012, 16:05
  4. Flash phone ở chế độ mất nguồn N72
    By hainguyen1203 in forum BB5
    Bài viết cuối: 20-04-2011, 12:40
  5. xin ae hướng dẫn chạy dead phone
    By vinhls in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 20-07-2009, 19:00
