Kết quả 1 tới 10 của 14
    Thành viên chính thức nguyengiap_84's Avatar
    Aug 2008
    cấm xuyên hà tĩnh
    Mặc định 6300 xin giúp
    nhờ các bác xem hộ em cái log 6300 chết nguồn em đã đóng lại hai con nguồn chạy nó báo thế này
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0843E1B
    Using device: HTI, FW ver: 00.24, SN: 000102C1
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Processing MCU file: rm217__07.21.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 229001032B2D7B56732725AA0A4336DE225CF484
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    eBB5ProtocolType: OLD
    Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
    Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF]
    CMT FLASH,NOR area [000006C0-0001FFFF]
    CMT FLASH,NOR area [00020000-0007FFFF]
    CMT FLASH,NOR area [00080000-000DFFFF]
    CMT FLASH,NOR area [00100000-001FFFFF]
    CMT FLASH,NOR area [00200000-0031FFFF]
    CMT FLASH,NOR area [00320000-0105FFFF]
    CMT FLASH,NOR area [01060000-01067FFF]
    CMT FLASH,NOR area [01068000-0107FFFF]
    erased in 6.703 s
    Prog.status for Asic CMT ...
    NAND: Status reported bad blocks.
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
    Error chk C7012D0103CD
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x00040000, Result: 0000
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00
    nhờ các bác xem giùm thank các bác!!!
    Moderator TÚ CÒI's Avatar
    hà nội
    chạy bằng box khác coi sao
    mx ko tin tưởng được
    Nov 2010
    thay cáp khác xem sao bạn lỗi
    Thành viên tích cực thanhlaman's Avatar
    lỗi cáp rồi thay cap khác chạy đi bạn.chúc thành công !
    LUÔN LUÔN LẮNG NGHE.LÂU LÂU.......... MỚI HIỂU.cần mua bộ vỏ zin THEO MÁY N86 8M GIÁ CAO.ai có xác liên hệ dùm em .phone:0984323352
    V.I.P Toan_MoBiLe_TN's Avatar
    đỏi cáp đa năng xem sao ko dc thay htavo luôn đi
    Oct 2010
    mang wa box khác cáp khác thử xem ntn
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    lấy usb phang nó bạn hiền
    yahoo: viethuy_mobi
    Thành viên mới toantkx92@'s Avatar
    May 2011
    ông a xóa full di nạp lại ok mà
    Thành viên kỳ cựu phamdienmobile's Avatar
    biên hòa - đồng nai
    vấn đề nằm ở đây nè bạn : MCU file: rm217__07.21.mcusw nạp ver cao hơn 1 chút đi bạn > bệnh này hay gặp ở mấy dòng BB5 về sau này lắm > đóng nguồn chuẩn lại rồi nạp ver cao hơn 1 chút ok liền > không phải ver đụng nóc nha anh em không thì dùng cable ốp lưng đi good
    Thành viên tích cực ANH_MOBILE's Avatar
    Feb 2012
    nông cống thanh hóa
    láy jaf đập dòng này ok nhất
  1. Trả lời: 9
  2. Trả lời: 19
  3. Trả lời: 21
  4. 6300 Cần anh em giúp đỡ gấp.
    By LienMobile in forum BB5
    Bài viết cuối: 25-06-2009, 09:10
  5. 6300 đuôi sạc như 6300 xịn sạc tiếp xúc kém
    Trả lời: 21
