Kết quả 1 tới 4 của 4
    Thành viên chính thức nguyendong_mobi's Avatar
    Mặc định 6720 RM_424 flash mất nguồn
    tình hình lúc đầu máy bị mã ảo vệ Factory không được mình flash lại giờ không lên nguồn
    bấm ngồn rung cái không thấy gì màn hình tối thui. đây là log mt của em nó ae cho ý kiến thanks all
    Box: CR V 3.001 22752
    Code: NK V 2.001 1056
    SN: 411979E81E
    Nokia Unlimited: 156 times started
    SonyEricsson Unlimited: 0 times started
    1600 RH-64_7.02 - Installed, Auto add.
    RM-559 - Installed, Auto add.
    rm-713 - Installed, Auto add.
    RM-504 - Installed, Auto add.
    Scanning files, please wait...
    Done
    Selected Highest installed version: 031.022
    Mcu rm424_031.022_prd.core.fpsx
    Content rm424_A_10w20v0.010.fpsx
    Ppm rm424_031.022_19.01_Vietnam_prd.rofs2.fpsx
    Ppm rm424_031.022_C08.01_GREY_prd.rofs3.fpsx
    Content rm424_031.022_U005.000_prd.uda.fpsx
    MemoryCardContent
    RM424_0633727_EASTASIA_1GB_2.0.fpsx
    ============= Set Flash mode for info =============
    Boot...
    Using Tx2 Data line.
    Trying boot BB5 phone...
    Invalid response from RAP3 boot( cable problem/damaged RAP3 chip/damaged phone power circuit
    Trying boot DCT4 phone...
    ============= Set FBus mode for info =============
    Pins:
    Mbus 1, Box Tx 1, Box Rx 0, Bsi 0
    BB5 PM back Phone is in: Phone is not responding!
    Processing File: rm424_031.022_prd.core.fpsx
    Boot...
    FAILED TO BOOT PHONE!!!
    Make sure that phone is connected.
    Boot...
    Boot...
    Boot...
    Boot...
    USB Deviced opened successfully.
    Switched to USB BUS
    Boot...
    \\?\nmwcd#vid_0421&pid_0106&if_oth#6&e12659f&0&00# {4f919102-4adf-11d5-882d-00b0d02fe381}
    RAPUv11_2nd.fg
    Sending ULO code
    RAPUv11_XSR17_alg.fg
    Pooling for device removal...
    Pooling for ADL device...
    CMT Certificates
    NPC 0x0200
    HWC 0x0100
    CCC 0x0200
    C:\Program Files\GriffinTeam\MT-Box\rpls\353213030780433_0.rpl
    Erase[312.75 MB]...
    erasing RAP [00020000 to 0003FFFF]
    erasing RAP [00060000 to 004DFFFF]
    erasing RAP [008E0000 to 0ACBFFFF]
    erasing RAP [004E0000 to 008DFFFF]
    erasing RAP [06A00000 to 09EBFFFF]
    erasing RAP [09EC0000 to 0ACBFFFF]
    erasing RAP [0ACC0000 to 0F63FFFF]
    in 1.89s
    Flash[87.66 MB]...in 15.00s
    * * Processed file in 21.09 seconds
    Processing File: rm424_A_10w20v0.010.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[2.31 MB]...in 0.39s
    * * Processed file in 0.42 seconds
    Processing File: rm424_031.022_19.01_Vietnam_prd.rofs2.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[37.05 MB]...in 6.56s
    * * Processed file in 6.58 seconds
    Processing File: rm424_031.022_C08.01_GREY_prd.rofs3.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[4.46 MB]...in 0.78s
    * * Processed file in 0.80 seconds
    Processing File: rm424_031.022_U005.000_prd.uda.fpsx
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[0.68 MB]...in 0.64s
    * * Processed file in 0.66 seconds
    Restarting device...
    Device disconnected.
    * * * Phone flashing done in 0:29 minutes
    Post Flash serial tunning of phone....
    Pooling mode for full factory set...
    Phone not responding, try to set manually!
    Dynamic camera configuration...
    Phone is in: Phone is not responding, power on phone!
    Boot...
    RAPUv11_2nd.fg
    Sending ULO code
    CMT Certificates
    NPC 0x0200
    HWC 0x0100
    CCC 0x0200
    C:\Program Files\GriffinTeam\MT-Box\rpls\353213030780433_1.rpl
    Erase[312.75 MB]...
    in 1.89s
    Flash[87.66 MB]...in 14.97s
    * * Processed file in 21.80 seconds
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Flash[2.31 MB]...in 0.41s
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    Boot...
    Erase[0.00 MB]...
    in 0.02s
    * * Processed file in 0.81 seconds
    Boot...
    Erase[0.00 MB]...
    in 0.00s
    * * Processed file in 0.67 seconds
    * * * Phone flashing done in 0:30 minutes
    mang qua hộp khác fash lại chạy deas usb xem tn bạn
    đã đổi dây đưa qua box hwk chạy rồi not ok
    ae ai có file chuẩn của em nó cho mình xin flash lại xem sao thanks all
    Thành viên chính thức truc2363's Avatar
    Mang yang / Gia lai
    bác thử có cái verd nào cao hơn quất cho nó phát thử ! good lock !
  1. Trả lời: 1
    Bài viết cuối: 12-02-2014, 21:22
  2. Trả lời: 5
    Bài viết cuối: 15-05-2013, 10:22
  3. Trả lời: 13
  4. 6100 mất nguồn check ok flash mất nguồn
    By kim nhut truong in forum DCT4 - WD2
    Bài viết cuối: 13-12-2009, 21:28
  5. 6720 sạc không đầy, cần giúp
    By nghiamobile2007 in forum BB5
    Bài viết cuối: 13-07-2008, 00:02
