    Thành viên chính thức HQuangmobile's Avatar
    Nov 2011
    Mặc định nhờ ae xem giúp log 3110c
    không hiểu sao máy hôm nay mình chạy cây nào cũng chết hết nhờ ae xem giúp mình dùng ufs+mxkey
    Version from phone: 07.21
    Version from file: OK.mc
    MXKEY Serial: [FT SCR2000 0] - C0817F31
    Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
    Module ver: 1.0.0.17602(14-06-2011), Library ver: 1.0.0.12920(08-10-2011)
    Reading Important data ...
    Reading RPL backup ...
    Reading Phone IDs ...
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 52.99 KB
    Sending Overflow Loader(0x2E4 bytes) ...
    Overflow loader running ..
    Sending CustomLoader ...OK
    PUBLIC ID: 2040000C28A07E56BEA0B32CA577633F03DD0FB4
    PRIVATE ID: BBA5725B640A5321421AA704D38890267C632C5B
    E-FUSE: 025B2301
    SEC ROM CRC: 40830040
    productData saved.
    Restarting phone ...
    Reading Secure Storage ...
    Reading SIMLOCK data ...
    Reading CERT data ...
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,CMT
    TransmissionMode: 16Bit
    CMT PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
    TransmissionMode: DDR&TX2
    Reading CMT HWC (0xD4 bytes).
    Flash Imei: 35196303853819
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35196303853819_BA CK.rpl"
    Processing MCU file: 3110c_TV_OK.mcusw
    [BB5,BB5 ALGORITHM] size: 14.49 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    ASIC MODE ID: 00
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT NOR area [00000000-000006BF] erased in 0.781 s
    CMT NOR area [000006C0-0001FFFF] erased in 0.250 s
    CMT NOR area [00020000-0007FFFF] erased in 2.094 s
    CMT NOR area [00080000-000DFFFF] erased in 0.250 s
    CMT NOR area [00100000-001FFFFF] erased in 0.391 s
    CMT NOR area [00200000-0031FFFF] erased in 5.937 s
    CMT NOR area [00320000-0105FFFF] erased in 1 min 5.797 s
    CMT NOR area [01060000-01067FFF] erased in 0.782 s
    CMT NOR area [01068000-0107FFFF] erased in 0.250 s
    Flash programming ...
    Error chk C7012D0103CD000090000000F1
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x00000400, Result: 0090
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00 00 90 00 00 00 F1 72
    bệnh này nan y thôi mà, kiểm tra lại cáp đi, cái này là dùng cáp đa năng này, PM yahoo mình tư vấn thêm cho, mình gặp vụ này hằng ngày mà
    Yahoo: chuonggc02@yahoo.com
    Oct 2010
    kt cáp chay bằng cáp da năng thử xem sao
    Thành viên mới hoang long ha noi's Avatar
    Aug 2010
    xem lại sợi cable đi bạn
    cửa hàng dtdd HOÀNG LONG
    dc đống đa hà nội
    Thành viên tích cực paulhung's Avatar
    Dec 2006
    3110c, 6300 chạy = mx chuối cả nải, lấy jaf múc e nó 1 phát tỉnh ngay
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Kiểm tra lại cọng cáp dùng cáp ốp lưng 6300 chạy lại xem.
    Thành viên tích cực VH-Mobile's Avatar
    Đà Lạt
    sao anh không chạy qua USB vậy nếu cáp đa nang chạy không được (em dảm bảo ok lien à)
    0967-225-468
  1. độ mic 3110c xin giúp
    By UNICEF in forum BB5
    Bài viết cuối: 18-07-2012, 11:01
  2. 3110c không hỗ trợ bộ sạc cần giúp gấp
    By vantuan0973286172 in forum BB5
    Trả lời: 20
    Bài viết cuối: 04-04-2012, 10:25
  3. Trả lời: 22
    Bài viết cuối: 02-12-2011, 22:12
  4. 3110c mất đèn cần anh em giúp.
    By nguyenlammobile in forum BB5
    Bài viết cuối: 29-12-2010, 11:51
