Kết quả 1 tới 3 của 3
    Thành viên tích cực KIÊN NGUYỄN MOBILE's Avatar
    Feb 2010
    TP HCM
    Mặc định Nhờ các bác coi dùm cái log E72
    Mình có cây E72 cứ mở nguồn là báo lỗi khởi động liên hệ với nhà cung cấp , mình đã chạy ver cao nhất rồi , còn đây là log của em nó , bác nào biết bệnh này xin chỉ dùm em cái nha .
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C084B543
    Using device: HTI, FW ver: 00.24, SN: 00010AEA
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    CMT Data :
    SYSTEM ASIC ID: 000000030000022600010007
    600C192102011104 [RAPUYAMA ver: 1.1]
    EM0 ID: 00001040
    EM1 ID: 00001030
    PUBLIC ID: 1D60001983880344D0EF72642A7DE1B7E4D4580B
    ASIC MODE ID: 00
    ROOT KEY HASH:
    25B977A055BE9B5DEC0C38A2A279C695
    ROM ID: 3E273BF637BE26FA
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.34.0 revision: 3.0 size: 0x3B40
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    eBB5ProtocolType: NEW
    TransmissionMode: DDR&TX2
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.34.0 revision: 3.0 size: 0xD4029
    CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E
    Original Imei: 35378404514353
    Original Product code: 0598498
    Bluetooth ID: 30385502E359
    SIMLOCK PA identifier:
    [0] PA_SIMLOC30
    Phone type: RM-530 (Nokia E72-1)
    SW version: V ICPR82_11w16.3.4 17-08-11 RM-530 (c) Nokia
    Imei plain: 35378404514353-6
    Battery voltage: 4340 mV, current: 0 mA
    ApeCoreSw:
    081.003
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353784045143536
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Moderator TÚ CÒI's Avatar
    hà nội
    coi lại chân pin là done thôi
    Log đẹp mà,vấn đề liên hệ nhà cung cấp ko liên quan tới mềm
    Feb 2010
    TP HCM
    ok để mình cai lại coi sao
  1. Anh em xem dùm con 6085 bus check bị lỗi gì dùm em với
    By hunglangtu_qb in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 23-08-2013, 09:11
  2. Xin a/e check dùm con 3gs và tư vấn dùm e
    By keylove779 in forum iPHONE 3Gs
    Bài viết cuối: 03-08-2013, 11:47
  3. Anh em chỉ dùm hộp mt-box
    By trangvinh in forum MT-Box
    Trả lời: 27
    Bài viết cuối: 26-12-2012, 10:37
  4. mấy anh xem dùm em cái log N70 với
    By liencuongmobile in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 04-04-2010, 11:33
  5. Mấy anh xem dùm log n-gate qd dùm
    By minhkhoa_iphone in forum DCT4 - WD2
    Bài viết cuối: 14-12-2009, 14:42
