Kết quả 1 tới 2 của 2
    Thành viên tích cực ANH_MOBILE's Avatar
    Feb 2012
    nông cống thanh hóa
    Mặc định 1200 chạy lổi
    n box 1st Boot: Ok, DCT4, UPP: 2293 [Rh-112] [2.2.0.0]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
    Algorithm: u3_st_i.fia, Ver: 4.79.0
    Algorithm Ok, MSID: 843BC5E1BC7828A7C1C8F164BC
    Decoded MSID: 3E4EBAE9-00C8102A-A9000000
    Encoded FAID: BC5D146F-E9F6D34F-7D928BCE
    IMAGE: rh112_004.030
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
    Erasing: 0x01010000-0x013AFFFF ...
    Erasing Error: 8, at: 0x01100000-0x0111FFFF, Time: 02:10
    Process Failed, Repowering Mobile CHẠY BĂNG JAF
    MCU ID: 0x2293
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Users\LONG\Desktop\RH-112\rh112_004.030
    Phone Type:
    PPM Flash file: C:\Users\LONG\Desktop\RH-112\rh112_004.03mr
    Phone Type:
    CNT Flash file: C:\Users\LONG\Desktop\RH-112\rh1120_nai04.03mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Users\LONG\Desktop\RH-112\rh112_004.030
    Booting phone...
    MCU ID: 0x2293
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID decoded: 3E4EBAE900C8102AA9000000
    FAID: BC5D146FE9F6D34F7D928BCE
    Erasing...
    Found 5 interval(s) to erase
    Error erasing area: 01110000 - 0112FFFF LỔI NÀY LÀ LỔI IC GÌ
    Moderator TÚ CÒI's Avatar
    hà nội
    tình trạng máy ra sao,nói rõ chút đi bạn
    Máy con chưa xóa được
    Check lại cáp đi đã
  1. Trả lời: 14
    Bài viết cuối: 15-08-2011, 20:58
  2. máy 1200 chạy không đồng bộ được
    By cam binh in forum DCT4 - WD2
    Bài viết cuối: 28-04-2011, 10:15
  3. 1200 màn hình chập chờn
    By thanhnhanmobile in forum DCT4 - WD2
    Bài viết cuối: 04-07-2010, 09:26
  4. 1200 chạy chậm,có sóng mà ko gọi dc
    By IC.NGUON in forum DCT3-DCTL
    Bài viết cuối: 07-05-2009, 18:11
  5. Trả lời: 2
    Bài viết cuối: 21-04-2009, 09:25
