    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định 1202 xin giúp
    MÁY 1202 NẰM ĐÈ LÊN MẤT NGUỒN , ĐÃ TEST MÀNG HÌNH VÀ MẠCH ĐÈN OK, BẮM NGUỒN KIM DÒNG NHÍT NHẸ,
    EM FLASH THÌ BÁO LỔI THẾ NÀY, XIN AE CHỈ GIÁO , THANKS ALL
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
    ASIC ID: 0x2293 [UPPCosto ver: 2.0]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: A97E 91B0 2A81 7340 C29B E07A 5A24 4814
    Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
    UEM ID: 00940B45A3BDA66
    ASIC type: 11
    UEM Imei: 35338604396278
    Flash Imei: E4F710768B5CF3
    Invalid imei checksum !
    Processing MCU file: rh112_004.030
    [DCT4,DCT4 ALGORITHM] size: 2.29 MB
    Supported Ids: 2293
    UEM ID: 00940B45:2984DA60
    Area [01000000-0100FFFF] erased in 0.969 s
    Area [01010000-013AFFFF] erased in 56.938 s
    Area [013B0000-013EFFFF] erased in 3.984 s
    Area [017C0000-017EFFFF] erased in 0.016 s
    Area [01FC0000-01FEFFFF] erased in 0.015 s
    Flash programming ...
    Programming completed in 18.140 s
    File Processed in 1 min 26.859 s
    Processing CNT file: rh1120_nai04.03mr
    [DCT4,DCT4 ALGORITHM] size: 110.54 KB
    Supported Ids: 2293
    ExtBUSC: 2100 9010 2200 0300 C201 2000 0020 4000
    Area [01380000-013AFFFF] erased in 2.953 s
    Programming completed in 0.859 s
    Content extract fail, continue anyway ...
    File Processed in 1 min 10.094 s
    Processing PPM file: rh112_004.03mr
    [DCT4,DCT4 ALGORITHM] size: 1.15 MB
    Supported Ids: 2293
    Area [01240000-0124FFFF] erased in 0.984 s
    Area [01250000-0137FFFF] erased in 18.734 s
    Programming completed in 9.109 s
    File Processed in 35.547 s
    Total time for flashing process(boot+erase+write) was 3 min 12.516 s
    Dec 2011
    còn đây la log check
    ASIC type: 11
    Flash Imei: 95FF505B86CF12
    MasterCode: 40F7117441
    Thành viên tích cực ngoc151na's Avatar
    Apr 2011
    CÓ PHẢI CHẠY ĐẾN FILE CNT BÁO LỖI BẤM CANCEL chạy tiếp nhung ko dông bộ đc phải ko>>>>thay cpu >>done..hôm truoc thay ic nguồn..flash rồi ko đc ..cuối cùng là cpu
    GIA HU: dechcanyeudetienuongruou151
  4. ( ngoc151na ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (17-02-2012)
    Dec 2011
    đúng rồi bạn, chạy tới đó là báo vậy đó
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    khò lại CPU sau đó chạy lại = ok. chắc hở chân CPU rồi
  7. ( nhanvnn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    99999 (17-02-2012)
  8. #6
    Dec 2011
    thanks ae, để thử rồi cho kết quả sau
  1. cần pro mod giúp em phát 1202 liệt 1 4 *
    By kythuat.GSM in forum DCT4 - WD2
    Bài viết cuối: 26-04-2012, 11:50
  2. 1202 nhờ anh em giúp với
    By hientrang.mobile1 in forum DCT4 - WD2
    Bài viết cuối: 17-09-2011, 11:08
  3. Trả lời: 0
    Bài viết cuối: 19-07-2010, 08:52
  4. Trả lời: 6
    Bài viết cuối: 15-02-2010, 09:38
  5. nhờ anh em xem giúp log 1202
    By ThanhHai_GSM in forum DCT4 - WD2
    Bài viết cuối: 09-02-2010, 19:06
