Kết quả 1 tới 10 của 10
    Thành viên chính thức nguyenlaluong's Avatar
    Mặc định 6300 chạy phần mềm báo lỗi xin giúp thank
    log chạy bang Mx Key nè xin giúp MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C08598C8
    Connection status: UHCI:HUB::USB 2.00 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.70
    Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011)
    Processing MCU file: rm217__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    Waiting for USB device ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 472EEA3
    CMT SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
    CMT EM0 ID: 00000232
    CMT EM1 ID: 00000353
    CMT PUBLIC ID: 1630020F05038D56607058D2DAA01104ECFD1EFF
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROM ID: 191EC665DFAAF68F
    Flashing CMT Update Server Data, ULO: 0x38C0 bytes
    Update Server code succesfully sent to phone.
    Flashing CMT Update Server Data, UPDAPP: 0x3CA00 bytes
    Flashing CMT Update Server Data, PASUBTOC: 0x4A9C0 bytes
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 2434194C
    Verifying communication to device OK.
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.390 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.015 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.187 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.141 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.234 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.563 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 40.843 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.407 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.015 s
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    Selecting first CMT PAPUB block with matching RootKey.
    CMT PAPUBKEYS: 7F7E6491 [RAP Certificate 52 v1] sent
    CMT UPDAPP block sent
    Error while programming [00] at 0x00070400, Result: 0000
    V.I.P ThanhHai_GSM's Avatar
    chạy usb thử, không được có atf flash là ngọt
    chạy usb cũng khôngn được xi giúp thank.
    V.I.P ĐƠ_NGUYỄN's Avatar
    mang qua phonix chạy xem sao bạn hiền
    Thành viên tích cực ko.ko80's Avatar
    Jul 2011
    bác thử backup imei &simlock lại
    rùi xóa full xong rùi nạp lại file đụng nốc xem sao
    May 2011
    Hà Nội City
    che chân vpp lại rùi lấy cáp ốp lưng thử xem thế nào
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    Lấy box khác flash lại check cáp lại cho kĩ không thì dùng sợi USB cho chắc em nó tỉnh ngay thôi
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Đem qua box khác flash hoặc chạy die usb by phonenix xem.
    Feb 2011
    thanh hóa
    lấy phonenix và xơi đi you ver cao nhất ko cần tiếng việt .lên ok đi cái đã rồi nạp lại tiếng việt sau
    call :0976 001 628
    Thành viên mới 1quachuoi9's Avatar
    Nov 2011
    Ninh Thuận
    lấy MX chạy ngọt ngào bằng cable úp lưng luôn tc khi chạy bạn click vào muc 128kl Ok liền ah làm đc thì thank ! cái khích lệ tinh thần nha Bạn Good luck !
  1. Trả lời: 9
  2. 6300 chạy phần mềm báo lỗi
    By minhtan7915 in forum BB5
    Bài viết cuối: 08-07-2010, 23:13
  3. 6300 chạy phần cần giúp
    By thanhdo07072004 in forum BB5
    Bài viết cuối: 13-12-2009, 06:12
  4. 6300.chạy phần mềm ko được
    By tiepmobile in forum BB5
    Bài viết cuối: 09-10-2009, 22:29
  5. Trả lời: 8
    Bài viết cuối: 13-11-2008, 16:49
