Kết quả 1 tới 2 của 2
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định SIEM Tools (v14.7) - FIRST IN THE WORLD - BootCore factory open BUS managing
    There is new update for SIEM Service Tools (v14.7)
    new features:
    - improved BootCore procedures
    - support for new PCB types (OTP empty models - SGOLD)
    - BootCore IMEI for OTP empty boards advanced functions added
    - improved Generate BOOT_PASS function (for OTP empty boards)
    - factory BUS opened BootCore functions added (detecting, opening, closing, changing) - FIRST IN THE WORLD
    - autodetect of BootCore type, flags and settings (for all groups of SGOLD models)
    - fullflash BootCore writing modes - auto generate IMEI for BootCore and EEprom in same time (for repairing OTP Empty phones)
    more info:
    www.martech.pl/ts
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
    Executive Administrator taihv™'s Avatar
    Nov 2006
    Hà Nội
    Mặc định Somes more info about this nice update!
    During fullflash with selected BootCore writing, if you have OTP empty board, program can't get IMEI from OTP. Program will ask if get IMEI from EEProm (if selected for fullflash writing), or you can also enter IMEI manually. Of course it's BootCore IMEI. So if you have OTP empty board, you can flash it in ONE STEP:
    - fullflashing firmware+FFS + EEprom + repair IMEI in EEprom + write BootCore + generate bootcore HASH and Bootcore IMEI
    so in other word - all you need to alive phone (now with OTP empty boards too, and with advanced functions)
    functions detects if Bootcore is correct, and many other things... (for more safe operations)
    If you press generate boot_pass on otp empty board, program will ask for IMEI that you want to use for generate it... (in old updates not possible)
    Bus opened phone can connect even in NORMAL MODE
    so you can 1) connect testpoint, use this function (make "factory opened" bootcore) and from now - your phone will connect via cable without TP in normal mode - even on different programs.
    if you want to close bootcore back - use function "close bootcore access".
    IT'S NOT FIRMWARE PATCH. It's factory, original feature.
    easier and faster than generating BOOT_PASS...
    also you can close bootcore access and generate new hash and put bootcore IMEI in one step (selecting check box)
    Advanced procedures checking bootcore types, bootcore states, bus state (factory opened for example). additional tips in many functions, show new informations - for example after open fullflash when bus is opened in bootcre, etc...
  1. SIEM Service Tools (v2.9)
    By Hieu BMT in forum Martech
    Bài viết cuối: 23-12-2006, 03:37
  2. Trả lời: 0
    Bài viết cuối: 30-09-2006, 10:32
  3. SIEM Service Tools v12.5
    By HVmobi in forum Martech
    Bài viết cuối: 02-08-2006, 12:01
  4. SIEM Service Tools ( v12.4 )
    Bài viết cuối: 26-07-2006, 14:28
  5. SIEM Service Tools ( v12.3 )
    Bài viết cuối: 16-07-2006, 18:33
