    Thành viên chính thức longthuanthien's Avatar
    Mặc định n81 rm-223 cần giúp
    tình hình là em nhận 1 con máy ko có tieng việt em chạy pm tiêng việt rùi giờ ló lại ko lên nữa các chuyên gia cho em biết tại sao với và khắc phục kiểu gì với
    PHP Code:
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB3], SNC08147F3
    Using device
    USB Phonet  and HTIFW ver00.50SN0000380A
    Connection status
    UHCI:HUB::USB 2.00 (Full-speed)
    Drivernmwcdcver7.1.32.70
    Module ver
    1.0.0.19815(08-01-2012), Library ver1.0.0.13716(10-01-2012)
    Make sure USB cableBattery and charger are removed from device.
    Insert USB cableBattery back to device(make sure to have fully charged battery).
    Insert Charger or Press phone's power button(if flashing doesnt start automatically)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
    CMT EM0 ID: 00000295
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0890000E357B00580596991C3377541F4B784FAA
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
    CMT ROM ID: A8C1D6713E691FF8
    Loading CMT secondary boot code
     SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 11.14.0 revision: 2.0 size: 0x3B80
     Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
    Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
    Storage2: 0400 0000  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030  - 0000 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.5
    Loading CMT update server data
     Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5]  version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0xFF bytes).
    Reading CMT VARIANT (0x0 bytes).
    Reading CMT CCC (0xFF bytes).
    Reading CMT HWC (0xFF bytes).
    Reading CMT R&D (0xFF bytes).
    Reading CMT PARTNERC (0x0 bytes).
    Waiting for USB device removal ...
    Waiting for device boot up ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 25408D92
    Device connected: nmwcdc\Nokia N81 USB Phonet, PORT_ID: 259CD0F
    Verifying communication to device OK.
    Phone type: RM-223 (Nokia N81)
    SW version: V 06wk41v62.4 04-12-08 RM-223 (c) Nokia
    Imei plain: 35699301316080-5
    Product code: 0550142
    Battery voltage: 3770 mV, current: 104 mA
    ApeCoreSw: 21.0.010
    Language Pack:
    - not available.
    SLPA ver[2]: PA_SL2 (15 digit NCK)
    SIMLOCK seems to be valid
    SUPERDONGLE_KEY seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 356993013160805
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    PROFILE_BITS: 0000000000000000
    BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.235 s
    Nov 2010
    chắc là bạn chạy ver thấp hơn nên em không lên nạp lại ver cao hơn xem sao
    log đẹp mà
    V.I.P BinhMinhGSM's Avatar
    Apr 2008
    Vĩnh Long->Đà Nẵng
    đưa sang phoenix flash phát cho nhẹ nhàng lụm lúa.
    Moderator TÚ CÒI's Avatar
    hà nội
    File lỗi hoặc do MX cà tưng
    Đem qua phoenix múc đi,not ok thì load file khác nhé
    Buôn Ma Thuột City.
    Log quá đẹp rồi ,bạn thử tải file khác về chạy lại cho nó cái ver cao hơn coi sao
    : 0934.80.22.28 .
