    Administrator saigonmobile's Avatar
    Aug 2006
    Tp.Hồ Chí Minh
    Mặc định GPP Sim unlock iphone 4s tự động kích hoạt có sóng.
    GPP Sim unlock iphone 4s Ver 5.0 , 5.01 support tất cả nhà mạng tự động có sóng như máy quốc tế.
    Bật nguồn lên có sóng như máy quốc tế không cần thao tác gì hết , chế độ 2g , 3g ok hết . Thời gia có sóng trong vòng 3 tới 10 giây. Đã tested .
    Giá 1 - 4 cái : 200.000 VND
    Giá 5 - 9 cái : 150.000 VND
    Giá 10 cái trở lên : 100.000 VND
    Bảo hành 3 tháng 01 đổi 01
    Chú ý : Giá này chỉ áp dụng cho cửa hàng.
    GPP Sim for GSM iPhone 4S :
    • GPP Sim True Plug-and-Play Unlocking SIM Interposer
    •No Need to Dial International Emergency Number 112
    •Untethered Unlock with no Jailbreak Required
    •Compatible with all GSM iPhone 4S SIM Cards
    •Complete Unlock with all 2G and 3G data services
    •No SIM Card Cutting or Physical Modifications
    •Works on iOS 5.0, 5.0.1
    •Works on Baseband 1.0.11, 1.013, 1.0.14
    •Guaranteed Better Reception than Previous
    •Decreased Power Consumption
    Product Description
    There is now no need to dial the international emergency number (112) during installation or when rebooting your iPhone 4S. Our learning technology allows for true plug-and-play iPhone 4S unlock solution. Beware of solutions that require you to CONNECT to an emergency number. This violates telecommunication abuse policies and lead to service cancelation on some networks.
    Decrease Power Consumption
    The F981 chipset in our new GPP Sim is engineered to operate under the 3- volt standard. That means your battery will last just as long as it would without the . GPP Sim Beware of counterfeit solutions claiming to use a similar chipset. We’ve invested the time and money to engineer our new GPP Sim with better power efficiency. This kind of technology can’t be duplicated or implemented on cheaper chipsets.
    Now you can unlock your iPhone 4S with the re-engineered GPP Sim interposer. Our new technology takes advantage of a new exploit that fully unlocks your iPhone 4S. It’s true plug-and-play functionality, so just pop it in and unlock your phone with the original sim card. If you don’t have the original sim card, additional programming may be required. Further instructions will be sent with your GPP Sim package.
    Untethered Unlock with no Jailbreak Needed
    With our new GPP Sim , you won’t have to connect to any external device to unlock your iPhone 4S. Even better, jailbreaking is not necessary so you won't void your Apple warranty.
    The new GPP Sim is now a single interposer that works for all networks. It actually “learns” your network, so there is no need to select a specific GPP Sim for your service carrier. A new GPP Sim comes in learning mode, but after inserting the GPP Sim and your SIM card in your iPhone 4S, our technology learns your network types and settings for a true plug-and-play unlock solution.
    One caveat of this exploit is that, if for some reason you need to change your current SIM with a SIM card from a different carrier, you will need to reset your GPP Sim with the reset SIM included with your genuine GPP Sim. Beware of other solutions that claim to circumvent this issue. It is simply not possible when taking advantage of this new exploit in the iPhone 4S firmware.
    Complete Unlock with all 2G and 3G Data Services
    Purchase genuine GPP Sim products and completely unblock all 2G and 3G data- transfer functionality. By default, your network carrier has blocked data network settings inside your iPhone 4S firmware. You will need to use the original network carrier’s SIM to activate your iPhone, and our GPP Sim will unlock all functionality available by your network.
    Be aware that some telecommunication carriers restrict data services to network phones only. Unfortunately, this limitation is unrelated to SIM cards and phone locking technology, so there is no phone unlocking solution that can guarantee connectivity to every data network. Check with your intended carrier to confirm data networks like 2G and 3G services are allowed on out-of-network phones.
    Guaranteed Better Reception than Last Generation Unlocking Solutions
    Now that we no longer take advantage of the old exploits, we’ve re-engineered the GPP Sim for enhanced signal strength with strong, consistent voice and data communication. Now there is no compromise in reception when choosing genuine GPP Sim products.
    Anh em nào có nhu cầu xin vui lòng liên hệ :
    CTy TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    Địa chỉ : 693 Đường 3 tháng 2 Phường 6 Quận 10 Tp. Hồ Chí Minh
    Điện Thoại : 08.9572152 - 08.8.57.57.07 - 0903303717
    YM : saigonmobile_vn
    Skype : saigonmobile
    MSN : support@saigonmobile.vn
    www.saigonmobile.vn
    UnlockOnline - Hoang Thong Mobile Phone Co., Ltd.
    CTY TNHH VIỄN THÔNG HOÀNG THÔNG
    ĐT/FAX :028.3.9572152 - 028.3.8575707 - 0283.9574129
  2. ( saigonmobile ) đã được 4 thành viên cám ơn vì bài viết hữu ích!
    ĐƠ_NGUYỄN (02-03-2012), minhsang287 (27-02-2012), minhtanmobile (29-02-2012), vangayeu (02-03-2012)
    Thành viên mới HPT-Telecom's Avatar
    Jun 2011
    sim nay ngon
    Aug 2006
    Tp.Hồ Chí Minh
    Update ngày 01/03/2012
    GPP Sim unlock iphone 4s tự động có sóng.
    Giá 1 - 4 cái : 500.000 VND
    Giá 5 - 9 cái : 450.000 VND
    Giá 10 cái trở lên : 400.000 VND
    BR,
    saigonmobile
    Thành viên mới luongvansang's Avatar
    Nov 2010
    lên cho a xuân có kèo thơm nà....
    Thành viên mới o0osquallo0o's Avatar
    Feb 2010
    đã nhận được sim sóng giá tốt
    V.I.P minhphuc's Avatar
    Apr 2006
    lên buổi sáng tốt đẹp nè!
    Thành viên mới tnqbao-vn's Avatar
    May 2010
    Sim ok sao em phone thì hết hàng rồi anh? chừng nào mới lấy về?
  9. #8
    Aug 2006
    Tp.Hồ Chí Minh
    Update ngày 14/03/2012
    GPP Sim unlock iphone 4s AT&T tự động có sóng như máy quốc tế .
    Giá 1 - 4 cái : 350.000 VND
    Giá 5 - 9 cái : 300.000 VND
    Giá 10 cái trở lên : 270.000 VND
    BR,
    saigonmobile
  1. Nhận repair và Unlock máy HTC G2 T-mobile mua code nhập OK mà không có sóng hoặc máy chưa unlock
    By saigonmobile in forum Dịch vụ unlock trực tiếp điện thoại di động
    Trả lời: 20
    Bài viết cuối: 13-01-2016, 10:55
  2. R-Sim Ultra S Ver 3.23 tự động có sóng unlock iphone 4s
    By Hoang Thong Mobile in forum GIỚI THIỆU THIẾT BỊ - CABLE - GIẢI PHÁP MỚI NHẤT
    Trả lời: 39
    Bài viết cuối: 08-05-2014, 13:05
  3. Trả lời: 3
    Bài viết cuối: 17-02-2013, 13:55
  4. Trả lời: 8
    Bài viết cuối: 07-01-2012, 21:13
